    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • kaluK Offline
      kalu
      Hi:
      Can you fix the problem with Sketchu 8 and works with other plugins or we need to keepp using the older version?.... ๐Ÿ‘Ž
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        Jim
        After you see the green dots, press the ENTER key.
        • fuzzionF Offline
          fuzzion
          That works ...You are a legend mate ๐Ÿ‘
          "Only the dead have seen the end of war" - Plato
            lapx
            Can the settings be saved to the harddrive in a file to be shared with others?
              tak2hata
              Hi fuzzion,gr8fzy1,kalu and Jim.
              I'm sorry about not visitting here recently.
              Thank you very much for this solution.
              In Webdialog,
              "Preview fur" makes only green points for examining density.
              "Make fur" makes furs.
              In Inputbox,
              "OK" button makes preview points everytime.
              after that ,press Enter key to make fur.
              or press ESC key to return Inputbox.
              Hi,rombout.
              Perhaps this is not solution,I think now.
              The First Idea:
              Make fur is only makes on faces.(and mesh)
              When the mesh is in group or component and selecting group,MakeFur doesn't work.
              Open the group and select faces or meshes.
              The Second Idea:
              That is bug.
              I didn't solve the problem about webdialog in mac os ,yet.
              If it does not make fur by using inputbox too,this problem is bug in recent version.
              So I will upload older versions.
              Thanks.
              by TAK2HATA
              • JClementsJ Offline
                JClements
                ? Wondering if anyone familiar with the various settings could produce a PDF (or some other document type) that would explain and diagram each of the parameters. ?
                • F Offline
                  Fletch
                  JC,
                  Does THIS help at all?
                  http://twilightrender.com/phpBB3/download/file.php?id=3803
                  Fletch
                  Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                    JClements
                    Hi Fletch:
                    Yes it does. What a nice Christmas present.
                    Regards,
                    John
                      rsalgadojf
                      Itยดs very good but the file came from 27mb to 100mb!
                      So difficulty
                      • RichardR Offline
                        Richard
                        Hey Fletch thanks mate for posting that reference, will help most people a BUNDLE! ๐Ÿ‘
                        BUILTBRAND.COM.AU
                          keanuar
                          this plug-in is SICK!!! save me tones of time when rendering in vray. no need to constantly tweaking the bump & displacement again. good job buddy!
                            JavaKom09088
                            @xrok1 said:
                            8-) this is greaaaat!
                            hi, may i know what is ur setting for this? i just cant create such natural look of the grass distribute on the ground... thank you
                            • plot-parisP Offline
                              plot-paris
                              hey Fletch, really great reference card. if plugin creators were able to add information to the instructor window in SketchUp, it should be this reference card...
                                AcesHigh
                                its a great tool, but I never use it because file size gets so big and the scene so heavy. ๐Ÿ˜ž
                                  ramdelgp
                                  Veryy nice plugin...very usefull ๐Ÿ˜„ now saving more time on modeling exteriors ๐Ÿ˜›
                                    gospodja
                                    Hi, can someone help me.. Ive downloaded the plug in, extracted the files in the same folder as my other plugins for sketchup but still it doesnt appear within the plugin menu when I restart Sketchup.. any ideas? Thanks ๐Ÿ˜„
                                      There is only ONE file [.rb] and that goes into the Plugins folder; the remaining files stay inside their sub-folder [fur] that goes into Plugins... If you have misplaced files please tidy up... You should then get a 'menu item' under Plugins ?
                                        tspco
                                        Got a question, how do I grow grass on a large scale? Just copy and paste?
                                        SU make 2017, /Twilight Render Hobby
                                        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                          Comitre
                                          Hi, is my first time here, i would like to say thanx to everyone that are always running for help who needs... like me.
                                          So... i am trying to install the make fur plugin right now.
                                          Thank you all.
                                          Be blessed by the Force!
                                          (Sorry about my poor english)(Talking from Brasil)
                                          Bye. ๐Ÿ˜‰
                                            bizmen
                                            hi just back read only you will get fletch reference link.
                                            Cheers
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 28 / 33
