    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • kaluK Offline
      kalu
      I have the same results in Sketchup 8 Pro, they make some kind of dots that's it...
      The old version works but I wish the new version works in S8. Thank you for your hard work.
      the Plugins is awesome...
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • kaluK Offline
        kalu
        Hi:
        Can you fix the problem with Sketchu 8 and works with other plugins or we need to keepp using the older version?.... 👎
          Jim
          After you see the green dots, press the ENTER key.
          • fuzzionF Offline
            fuzzion
            That works ...You are a legend mate 👍
            "Only the dead have seen the end of war" - Plato
              lapx
              Can the settings be saved to the harddrive in a file to be shared with others?
                tak2hata
                Hi fuzzion,gr8fzy1,kalu and Jim.
                I'm sorry about not visitting here recently.
                Thank you very much for this solution.
                In Webdialog,
                "Preview fur" makes only green points for examining density.
                "Make fur" makes furs.
                In Inputbox,
                "OK" button makes preview points everytime.
                after that ,press Enter key to make fur.
                or press ESC key to return Inputbox.
                Hi,rombout.
                Perhaps this is not solution,I think now.
                The First Idea:
                Make fur is only makes on faces.(and mesh)
                When the mesh is in group or component and selecting group,MakeFur doesn't work.
                Open the group and select faces or meshes.
                The Second Idea:
                That is bug.
                I didn't solve the problem about webdialog in mac os ,yet.
                If it does not make fur by using inputbox too,this problem is bug in recent version.
                So I will upload older versions.
                Thanks.
                by TAK2HATA
                • JClementsJ Offline
                  JClements
                  ? Wondering if anyone familiar with the various settings could produce a PDF (or some other document type) that would explain and diagram each of the parameters. ?
                  • FletchF Offline
                    Fletch
                    JC,
                    Does THIS help at all?
                    http://twilightrender.com/phpBB3/download/file.php?id=3803
                    Fletch
                      JClements
                      Hi Fletch:
                      Yes it does. What a nice Christmas present.
                      Regards,
                      John
                        rsalgadojf
                        It´s very good but the file came from 27mb to 100mb!
                        So difficulty
                        • RichardR Offline
                          Richard
                          Hey Fletch thanks mate for posting that reference, will help most people a BUNDLE! 👍
                          BUILTBRAND.COM.AU
                            keanuar
                            this plug-in is SICK!!! save me tones of time when rendering in vray. no need to constantly tweaking the bump & displacement again. good job buddy!
                              JavaKom09088
                              @xrok1 said:
                              8-) this is greaaaat!
                              hi, may i know what is ur setting for this? i just cant create such natural look of the grass distribute on the ground... thank you
                              • plot-parisP Offline
                                plot-paris
                                hey Fletch, really great reference card. if plugin creators were able to add information to the instructor window in SketchUp, it should be this reference card...
                                  AcesHigh
                                  its a great tool, but I never use it because file size gets so big and the scene so heavy. 😞
                                    ramdelgp
                                    Veryy nice plugin...very usefull 😄 now saving more time on modeling exteriors 😛
                                      gospodja
                                      Hi, can someone help me.. Ive downloaded the plug in, extracted the files in the same folder as my other plugins for sketchup but still it doesnt appear within the plugin menu when I restart Sketchup.. any ideas? Thanks 😄
                                        There is only ONE file [.rb] and that goes into the Plugins folder; the remaining files stay inside their sub-folder [fur] that goes into Plugins... If you have misplaced files please tidy up... You should then get a 'menu item' under Plugins ?
                                          tspco
                                          Got a question, how do I grow grass on a large scale? Just copy and paste?
                                          SU make 2017, /Twilight Render Hobby
                                          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                            Comitre
                                            Hi, is my first time here, i would like to say thanx to everyone that are always running for help who needs... like me.
                                            So... i am trying to install the make fur plugin right now.
                                            Thank you all.
                                            Be blessed by the Force!
                                            (Sorry about my poor english)(Talking from Brasil)
                                            Bye. 😉
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 32
                                            • 33
                                            • 19 / 33
