    I can't find out the plugin I had used !
    18 Posts 8 Posters 1.4k Views 8 Watching
    • simon le bonS Offline
      simon le bon
      Hi guys, thanks for the help!
      I follow the search but I still don't recover the plugin..
      I agree with ThomThom:
      @thomthom said:
      • the holes in this model seem to have been carved/cut out.
      It means also that I don't remember how it was working.
      The picture is dated from 7 of January 2010: one year ago.
      simon
        The output appear to have very fine curves - must be very small edges. ...I see it's rendered - is it not a texture with transparency mapping?
          simon le bon
          Yes! yes! it is rendered, I was missing this 😆
          Rendered in Kerkythea.
          I have discovered in my Kerkythea pictures folder another try I had done..
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thWire016.jpg
          I don't find the corresponding skp, but I have found the xml file !!
          A quick try with voronoy procedural as Clip mapping: and
          Eureka, you where right!! Bravo thomthom 👍 👍 😎
          $$$$$\ SOLVED BY TMTM //££££££££
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_voronoiProcedural.jpg
          ++simon
            Builder Boy
            Is there a plugin that will do that without rendering?
            All my plugins
              But now I want a plugin that eats my models 🎉
              • numbthumbN Offline
                numbthumb
                I doubt that woodworkers would welcome such plugin 😄
                But I do like the idea.
                Comfortably numb...
                  http://www.freeclipartnow.com/d/35351-1/sherlock.jpg
                    Seems you can make the same with this "Random Selection" by TIG 💚
                      simon le bon
                      Hi Pilou,
                      Nice to see you after seems to me a long time.
                      Wish you a Happy New Year 👍 ☀
                      Hum! I just had made a little test with Tig's random select, and that confirms what I thought: we can't obtain the same result because even if we reveal the hidden geometry on a subdivided shape, we are going to deletes mainly triangles.
                      To obtain the same result we have to draw them by hand (seem's to me to be the only solution 😕 )
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thTiG_RandomSelect02.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thTiG_RandomSelect01.jpg
                      Cheers, simon.
                        There is not in the Selection Toys by Thomthom something like "extend an existing selection" ?... (not yet researched) 😳
