    I can't find out the plugin I had used !
    18 Posts 8 Posters 1.3k Views 8 Watching
    • simon le bonS Offline
      simon le bon
      Hi SCFers,
      I would like recover the plugin I had used to make the random holes in the escalator!
      I have scanned all my (how many!) plug links without success.
      Re: the escalator itself had been made with 1001bit tools
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thescalator2_1000.jpg
      Any Idea?
      *simon
      • dereiD Offline
        derei
        Would it be Random Delete ?
        • mitcorbM Offline
          mitcorb
          The word "random" could be a clue?
          I would be interested in a tool that "deteriorates" or "delapidates".
          And I am guessing perhaps something in Didier Bur's collection? I really don't know.
          EDIT: Well, dereeei done beat me to it 😆
            hm... not sure if that is the plugin used. That plugin removed random entities in the current selection - the holes in this model seem to have been carved/cut out.
            • numbthumbN Offline
              numbthumb
              Judging by the way your escalator looks, Simon, it must have been bomb.rb or something like that. 😄
              (sorry for the OT)
              Comfortably numb...
                Doesn't bomb.rb just explode everything?
                  numbthumb
                  It does, I was only joking.
                  Comfortably numb...
                  • mitcorbM Offline
                    mitcorb
                    I know it doesn't matter here, but a spelling error occurred in my post above. The correct spelling is "dilapidate" of Latin origin having to do with scattering of stones. 😉
                      simon le bon
                      Hi guys, thanks for the help!
                      I follow the search but I still don't recover the plugin..
                      I agree with ThomThom:
                      @thomthom said:
                      • the holes in this model seem to have been carved/cut out.
                      It means also that I don't remember how it was working.
                      The picture is dated from 7 of January 2010: one year ago.
                      simon
                        The output appear to have very fine curves - must be very small edges. ...I see it's rendered - is it not a texture with transparency mapping?
                          simon le bon
                          Yes! yes! it is rendered, I was missing this 😆
                          Rendered in Kerkythea.
                          I have discovered in my Kerkythea pictures folder another try I had done..
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thWire016.jpg
                          I don't find the corresponding skp, but I have found the xml file !!
                          A quick try with voronoy procedural as Clip mapping: and
                          Eureka, you where right!! Bravo thomthom 👍 👍 😎
                          $$$$$\ SOLVED BY TMTM //££££££££
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_voronoiProcedural.jpg
                          ++simon
                            Builder Boy
                            Is there a plugin that will do that without rendering?
                            All my plugins
                              But now I want a plugin that eats my models 🎉
                                numbthumb
                                I doubt that woodworkers would welcome such plugin 😄
                                But I do like the idea.
                                Comfortably numb...
                                  http://www.freeclipartnow.com/d/35351-1/sherlock.jpg
                                    Seems you can make the same with this "Random Selection" by TIG 💚
                                      simon le bon
                                      Hi Pilou,
                                      Nice to see you after seems to me a long time.
                                      Wish you a Happy New Year 👍 ☀
                                      Hum! I just had made a little test with Tig's random select, and that confirms what I thought: we can't obtain the same result because even if we reveal the hidden geometry on a subdivided shape, we are going to deletes mainly triangles.
                                      To obtain the same result we have to draw them by hand (seem's to me to be the only solution 😕 )
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thTiG_RandomSelect02.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thTiG_RandomSelect01.jpg
                                      Cheers, simon.
                                        There is not in the Selection Toys by Thomthom something like "extend an existing selection" ?... (not yet researched) 😳
