    I can't find out the plugin I had used !
    18 Posts 8 Posters 1.6k Views 8 Watching
      hm... not sure if that is the plugin used. That plugin removed random entities in the current selection - the holes in this model seem to have been carved/cut out.
      • numbthumbN Offline
        numbthumb
        Judging by the way your escalator looks, Simon, it must have been bomb.rb or something like that. 😄
        (sorry for the OT)
        Comfortably numb...
          Doesn't bomb.rb just explode everything?
            numbthumb
            It does, I was only joking.
            Comfortably numb...
            • mitcorbM Offline
              mitcorb
              I know it doesn't matter here, but a spelling error occurred in my post above. The correct spelling is "dilapidate" of Latin origin having to do with scattering of stones. 😉
              • simon le bonS Offline
                simon le bon
                Hi guys, thanks for the help!
                I follow the search but I still don't recover the plugin..
                I agree with ThomThom:
                @thomthom said:
                • the holes in this model seem to have been carved/cut out.
                It means also that I don't remember how it was working.
                The picture is dated from 7 of January 2010: one year ago.
                simon
                  The output appear to have very fine curves - must be very small edges. ...I see it's rendered - is it not a texture with transparency mapping?
                    simon le bon
                    Yes! yes! it is rendered, I was missing this 😆
                    Rendered in Kerkythea.
                    I have discovered in my Kerkythea pictures folder another try I had done..
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thWire016.jpg
                    I don't find the corresponding skp, but I have found the xml file !!
                    A quick try with voronoy procedural as Clip mapping: and
                    Eureka, you where right!! Bravo thomthom 👍 👍 😎
                    $$$$$\ SOLVED BY TMTM //££££££££
                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_voronoiProcedural.jpg
                    ++simon
                      Builder Boy
                      Is there a plugin that will do that without rendering?
                      All my plugins
                      • Rich O BrienR Online
                        But now I want a plugin that eats my models 🎉
                          numbthumb
                          I doubt that woodworkers would welcome such plugin 😄
                          But I do like the idea.
                          Comfortably numb...
                            http://www.freeclipartnow.com/d/35351-1/sherlock.jpg
                              Seems you can make the same with this "Random Selection" by TIG 💚
                                simon le bon
                                Hi Pilou,
                                Nice to see you after seems to me a long time.
                                Wish you a Happy New Year 👍 ☀
                                Hum! I just had made a little test with Tig's random select, and that confirms what I thought: we can't obtain the same result because even if we reveal the hidden geometry on a subdivided shape, we are going to deletes mainly triangles.
                                To obtain the same result we have to draw them by hand (seem's to me to be the only solution 😕 )
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thTiG_RandomSelect02.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thTiG_RandomSelect01.jpg
                                Cheers, simon.
                                  There is not in the Selection Toys by Thomthom something like "extend an existing selection" ?... (not yet researched) 😳
