[Plugin] Export 2d with Alpha
Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
I know and it doesn't give me any file type to save it as at all.
You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
@thomthom said:
@gaieus said:
Edit; to me, it does not export with transparent background... Nor does it export only the active context.
What version of SU did you use?
Got a screencapture?The most recent one; SU 8.
Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
Well, sigh... I can always use LO for exporting png's with transparent background...
Maybe it's an XP thing?
I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
Just to narrow it down to a simple test case - can you try this one-liner?
<span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write_image</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">{</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">=></span><span class="syntaxstring">'C;\test.png'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">640</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">480</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">antialias</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">transparent</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">trueΒ </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Β </span>
Try what? Enter the ruby console? I get this:
If you set the background color to be 0,0,0 [pure-black] then the image will export with a transparent background in place of the 'pure-black', when you open it in Gimp or a web-browser etc you will see there is no background...
Should not need to do this - I export with the default SketchUp Sky - still I get transparency.
That's not entirely correct... iIF you have a Sky and/or Ground ticked in your Style you will not get a transparent background to the png for the areas that these parts 'cover'.
BUT if you have the Sky AND Ground un-ticked in your Style then I agree - the color of the Background itself is irrelevant because whatever it is when the have the png export transparency set 'on' that background is made 'transparent' - no matter what color it is - white, black, magenta or anything else! -
I get Transparency with Sky on. But not with Ground.
...Gaieus... do you have the Ground on?
Correction: Sky do appear when exporting. I just always tried with a view looking down so no sky was visible.
I find that both sky and ground obscure my png's background transparency ?
I need to have sky and ground both off to have a fully transparent background in the png, BUT even then shadows on the ground-pane will show up floating is space so you need to have that option off too... -
Don't know why I haven't seen this gem before today...
Awesome, Thomas...!
Thank you SO much...!! -
Hi Thom and TIG; you are right, when I turn ground and sky off, I can export with transparency.
And now I am banging my head to the wall (where is that smiley?
)This is exactly the way you need to set your style to be able to export your png with transparency!
Yea - we need that smiley.
This has been one for my Duh! list as well.
