    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 131.7k Views 42 Watching
      I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
        Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
        ๐Ÿ˜„
          Just to narrow it down to a simple test case - can you try this one-liner?
          <span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write_image</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">{</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">=></span><span class="syntaxstring">'C;\test.png'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">640</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">480</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">antialias</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">transparent</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">trueย </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">ย </span><span class="syntaxkeyword">)</span><span class="syntaxdefault">ย </span>
            Try what? Enter the ruby console? I get this:
              If you set the background color to be 0,0,0 [pure-black] then the image will export with a transparent background in place of the 'pure-black', when you open it in Gimp or a web-browser etc you will see there is no background... ๐Ÿค“test.png
                Should not need to do this - I export with the default SketchUp Sky - still I get transparency.
                  That's not entirely correct... iIF you have a Sky and/or Ground ticked in your Style you will not get a transparent background to the png for the areas that these parts 'cover'.
                  BUT if you have the Sky AND Ground un-ticked in your Style then I agree - the color of the Background itself is irrelevant because whatever it is when the have the png export transparency set 'on' that background is made 'transparent' - no matter what color it is - white, black, magenta or anything else!
                    I get Transparency with Sky on. But not with Ground.
                    ...Gaieus... do you have the Ground on?
                      Correction: Sky do appear when exporting. I just always tried with a view looking down so no sky was visible.
                        I find that both sky and ground obscure my png's background transparency ?
                        I need to have sky and ground both off to have a fully transparent background in the png, BUT even then shadows on the ground-pane will show up floating is space so you need to have that option off too...
                        • FrederikF Offline
                          Frederik
                          Don't know why I haven't seen this gem before today... ๐Ÿ˜ณ
                          Awesome, Thomas...!
                          Thank you SO much...!!
                          Cheers
                          Kim Frederik
                            Hi Thom and TIG; you are right, when I turn ground and sky off, I can export with transparency.
                            And now I am banging my head to the wall (where is that smiley?
                            http://twilightrender.com/phpBB3/images/smilies/wall.gif
                            This is exactly the way you need to set your style to be able to export your png with transparency!
                              Yea - we need that smiley.
                              This has been one for my Duh! list as well.
                                Thanks anyway (and again) for the plug however. I do not know if there is a solution in ruby but if not, I guess you have already updated the info on the first page.
                                Maybe a solution to temporarily disable ground and sky?
                                  Maybe the user want either one on/off...
                                    Thom,
                                    This is exporting for me? Ground/Sky off, BG is White and adding .png to file name when exporting but no joy! I know i've missed something here but re-reading the thread i can't pin it down?
                                      Can you post this joyless model? And/or screenshot?
                                        Just a warehouse model for testing before you know what ๐Ÿ˜‰
                                          Gimme model
                                            It was actually one of Pete's submissions.
                                            http://forums.sketchucation.com/viewtopic.php?p=198656#p198656
                                            But later I'll provide the model itself in case there's a difference
                                            • 2 / 8
