    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 127.8k Views 42 Watching
    • PixeroP Offline
      Pixero
      @thomthom said:
      β€’SketchUp 7 or newer
      @thomthom said:
      Added with the SU8 API.
      So...how do I get this to work with SU 7.1?
      It exports without transparency and always the whole model.
        Transparency? You can't.
        hmm, not on my machine - remember to Hide Rest of Model. WYSIWYG.
          rv1974
          Is there some way to separate shadows pass?
          • PixeroP Offline
            Pixero
            @thomthom said:
              No - I have no control of how it's generated. As you see from the sample I posted the shadows even comes from the whole model, not just what is visible.
              • PixeroP Offline
                Pixero
                This can help for a shadow pass: http://rhin.crai.archi.fr/RubyLibraryDepot/download.php?file=displaytemplate.rb
                And maybe a modification of my Shadow control script (http://www.pixero.com/downloads_sketchup.html) could be made to set everything not selected to: e.casts_shadows = false
                  archworks
                  Congratulations - one of the best for su 2d app
                    Hey, I did not see this, great plugin, thanks Thom! πŸ‘ πŸ‘ πŸ‘
                    Edit; to me, it does not export with transparent background... Nor does it export only the active context. 😞
                      What version of SU did you use?
                      Got a screencapture?
                      • HumpmetwiceH Offline
                        Humpmetwice
                        Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
                          After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
                            Humpmetwice
                            I know and it doesn't give me any file type to save it as at all.
                              You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
                              So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
                                The most recent one; SU 8.
                                Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
                                test2.avi
                                  That baffles me. I have no idea why this happens. Exactly the same works for me... ❓ πŸ˜• ❓
                                  test1.zip
                                    Well, sigh... I can always use LO for exporting png's with transparent background...
                                    Maybe it's an XP thing?
                                      I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
                                        Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
                                        πŸ˜„
                                          Just to narrow it down to a simple test case - can you try this one-liner?
                                          <span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write_image</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">{</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">=></span><span class="syntaxstring">'C;\test.png'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">640</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">480</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">antialias</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">transparent</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">trueΒ </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Β </span>
                                            Try what? Enter the ruby console? I get this:
                                            • 2 / 8
