    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 131.8k Views 42 Watching
    • HumpmetwiceH Offline
      Humpmetwice
      @thomthom said:
      After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
      I know and it doesn't give me any file type to save it as at all.
        You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
        So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
          @thomthom said:
          @gaieus said:
          Edit; to me, it does not export with transparent background... Nor does it export only the active context. 😞
          What version of SU did you use?
          Got a screencapture?
          The most recent one; SU 8.
          Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
          test2.avi
            That baffles me. I have no idea why this happens. Exactly the same works for me... ❓ πŸ˜• ❓
            test1.zip
              Well, sigh... I can always use LO for exporting png's with transparent background...
              Maybe it's an XP thing?
                I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
                  Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
                  πŸ˜„
                    Just to narrow it down to a simple test case - can you try this one-liner?
                    <span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write_image</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">{</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">=></span><span class="syntaxstring">'C;\test.png'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">640</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">480</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">antialias</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">transparent</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">trueΒ </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Β </span>
                      Try what? Enter the ruby console? I get this:
                        If you set the background color to be 0,0,0 [pure-black] then the image will export with a transparent background in place of the 'pure-black', when you open it in Gimp or a web-browser etc you will see there is no background... πŸ€“test.png
                          Should not need to do this - I export with the default SketchUp Sky - still I get transparency.
                            That's not entirely correct... iIF you have a Sky and/or Ground ticked in your Style you will not get a transparent background to the png for the areas that these parts 'cover'.
                            BUT if you have the Sky AND Ground un-ticked in your Style then I agree - the color of the Background itself is irrelevant because whatever it is when the have the png export transparency set 'on' that background is made 'transparent' - no matter what color it is - white, black, magenta or anything else!
                              I get Transparency with Sky on. But not with Ground.
                              ...Gaieus... do you have the Ground on?
                                Correction: Sky do appear when exporting. I just always tried with a view looking down so no sky was visible.
                                  I find that both sky and ground obscure my png's background transparency ?
                                  I need to have sky and ground both off to have a fully transparent background in the png, BUT even then shadows on the ground-pane will show up floating is space so you need to have that option off too...
                                  • FrederikF Offline
                                    Frederik
                                    Don't know why I haven't seen this gem before today... 😳
                                    Awesome, Thomas...!
                                    Thank you SO much...!!
                                    Cheers
                                    Kim Frederik
                                      Hi Thom and TIG; you are right, when I turn ground and sky off, I can export with transparency.
                                      And now I am banging my head to the wall (where is that smiley?
                                      http://twilightrender.com/phpBB3/images/smilies/wall.gif
                                      This is exactly the way you need to set your style to be able to export your png with transparency!
                                        Yea - we need that smiley.
                                        This has been one for my Duh! list as well.
                                          Thanks anyway (and again) for the plug however. I do not know if there is a solution in ruby but if not, I guess you have already updated the info on the first page.
                                          Maybe a solution to temporarily disable ground and sky?
                                            Maybe the user want either one on/off...
                                            • 2 / 8
