    How Many Susans Can Your Computer Do?
    35 Posts 18 Posters 4.8k Views 18 Watching
    • KrisidiousK Offline
      Krisidious
      200,000 Susans...
      shoot for 1 million tomorrow.
      By: Kristoff Rand
        @krisidious said:
        200,000 Susans...
        That would be:
        Edges: 92 600 000
        Faces: 38 000 00
        Triangles: 97 400 000
        Edges: 463 000 000
        Faces: 22 000 000
        Triangles: 629 000 000
        Good luck with that!
        • bmikeB Offline
          bmike
          pretty slow... to even snag a screen pic.
          dell m6400. not exactly a high horsepower machine.
          i did explode the original and made a new component with 'face camera' off. πŸ˜‰
          • bmikeB Offline
            bmike
            orbited slowly @ 100,000.
            almost made a 100k selection.
            and then 'sketchup has stopped working'.
            no 200k for me.
              No need to explode for that. You can change the component properties from the Component Browser.
              • bmikeB Offline
                bmike
                thanks... never use that feature (face camera).
                • jeff hammondJ Offline
                  click pic for bigger
                  i think it's just a matter of how long you're willing to wait.. going from 100,000 to 600,000 took around 40 minutes.
                    Krisidious
                    nice Jeff... how many did you select at the largest copy?
                    By: Kristoff Rand
                      100,000 was the most selected at once.
                      @tourniquetmaster said:
                      My result was 10,000 Susans (on a MacBook pro). Can you do better?
                      nah, you can do more than that.. those 600,000 susans are on a mbp also..
                        Builder Boy
                        YES!!! ONE MILLION!
                        I cheated a little 😳 I used guide points instead of Susans. and I kinda grouped them together as well. 😳
                        All my plugins
                          Aerilius
                          @builder boy said:
                          You can download a million here.
                          • jgbJ Offline
                            jgb
                            Way back when I first started with SU I did a comparison of groups to components on SU speed, response and file size.
                            Keep in mind, there is only ONE Susan component definition in SU, but the graphics processor (either hardware or software) is doing ALL the work here. The graphic engine calls up the components definition and reconstructs it for each instance it is displayed. Only a components definition pointer is retained for each instance in memory or file.
                            So what you are really measuring is how good the graphics portion of your computer is, not so much the computational portion, or even memory.
                            Now a group is fully defined in memory and file for EACH and EVERY instance in the model. Both the computation AND graphics engines are working here, more computational, less graphical.
                            Try your million Susans again, but first explode Susan's comp and group her. I'll bet you won't get anywhere near as many, but the pan speed may actually improve a bit.
                            jgb
                              Not quite - groups acts as components internally. When you copy a group you are making a new instance of that same group definition. The only difference is that groups are automatically made unique once you modify them.
                              • jgbJ Offline
                                jgb
                                I stand corrected. However the correction still maintains my statement that groups are defined fully in every instance, unlike just once for a component.
                                jgb
                                  Only when it's made unique.
                                  When you copy a group, you have two instances that both points to the same definition. You see in Entity Into that it lists how many copy there are of a given group. When it says you have more than one it's the same thing as if you had a component.
                                  • jgbJ Offline
                                    jgb
                                    Sounds reasonable, but, please explain why when I did my test years ago, the file with the copies of a group was consistently bigger than the same file of the same number of the same entities but as a copied component. And it started panning faster. (Not a lot but noticeable)
                                    jgb
                                      Don't know - not sure how things are stored in the .skp format.
                                        d12dozr
                                        100,000 Susans...adding any more takes f-o-r-e-v-e-r
                                        ASUS G73JW-XT1 Gaming Laptop
                                        i7-740QM
                                        NVIDIA GeForce GTX 460M
                                        (I know this isn't as many as some of the others, but since I did the test, I figured it'd be a waste not to share the results)
                                        http://goo.gl/f7ooYh
                                        • tpstigersT Offline
                                          tpstigers
                                          Wow. My computer had to go smoke a cigarette and take a nap after doing only one Susan.
                                          β€œI have an existential map; it has 'you are here' written all over it”
                                            Did you doSudan??? 😲
                                            • 2 / 2
