    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 97.5k Views 69 Watching
      πŸ‘
      This is going to be great for all those who model ships for instance...
      (Need a test forum, Thom? πŸ˜‰ )
        jonorman
        sweet.. πŸ˜„
          πŸ˜„ So I take it there is an interest for such a tool then - and not just me coding into oblivion. phew
          Why not coons surfaces, seems that is very similar? πŸ˜‰
          Until right now I'd never heard of coons surfaces...
          Does it possible to have more than 4 sides?
          No, there will be Tri and Quad Patches - these are combined into various configurations to create one surface. Like you do in 3DSMax's patch modelling.
          (And free or pay for ?)
          Most probable pay. This plugin is becoming rather complex. So I expect it to be something in the lines of Vertex Tools.
          When time is ready, yes. Before that there will be a new round of Vertex Tools. πŸ˜‰
          mhm. And airplanes, cars, product designs and whatnot.
          The parametric nature of it makes it easy to model in low subdivision and then just apply a model wide multiplier right before you export your final image or render. I'm thinking it should also be possible to have a LOD setting that will adjust the subdivisions of the meshes depending on the current viewport. (components will be a challenge here...)
            OK, let me know. And wow, new vertex tools, too!
            πŸ‘
            I don't care for cars and aeroplanes but like ships. Old ships especially.
            πŸ˜„
              chloesdad
              I purchased Vertex Tools, because it works, and I want to support the efforts of those of you who create quality plugins. It is, what makes SU a more powerful, useful product. I can't wait for Bezier Surface to become available. Fantastic, thanks in advance for your efforts!
                πŸ˜„
                How about old cars? πŸ˜„
                Cheers! πŸ˜„ πŸ‘
                  Well, they are nice, indeed. πŸ˜†
                    About coons surface πŸ˜‰
                    And scroll you have even the code (button "Show code" πŸ˜‰
                    • boofredlayB Offline
                      boofredlay
                      Looking forward to this one Thomas.
                      • jason_marantoJ Offline
                        jason_maranto
                        Wow, that looks like a cross between SDS and Sketchy FFD, I can see this useful for many things but especially cloth modelling. 😍
                        Best,
                        Jason.
                        • PixeroP Offline
                          Pixero
                          Looks great. I have the old Bezier patch plugin by Victor Liu but this looks so much better.
                          Just at the end after watching it two times I realised something... 😲 ...a transform gizmo!!!
                          Wow! Cant you make a version of the move, rotate and scale tools that uses the gizmo? πŸ‘
                          P.S. I just hope you haven't given up on the UV Tools plugin... πŸ˜’
                            Yup - the gizmo will find its way into Vertex Tools 1.1.
                            Wikii got a gizmo plugin available (I've not tried it) - though it says it'll work only until 2011.
                            In any case - once the gizmo is done (need to make the rotate, scale3d, scale2d and scale1d functions) it'd be easy to make a standalone gadget.
                              Nope - but it also needs this manupulator gizmo. Once that is done I hope to get a first release out.
                              Vertex Tools, UV Tools and Bezier Surface share some reusable components so work on one often means benefit for the other. For instance, UV Tools will be of use for Bezier Surface as bezier surfaces are predictable surfaces that makes them easier to map.
                              • W Offline
                                Whaat
                                Looks awesome Thomthom!
                                • mitcorbM Offline
                                  mitcorb
                                  I guess this is an inevitable next step after Vertex Tools. You have proven you are a master, already.
                                  • Bob JamesB Offline
                                    Bob James
                                    Sign me up
                                    Gizmos in Vertex Tools πŸŽ‰
                                      Panga
                                      As a vertex tool user, I'm also looking forward for this plugin !! Thanks in advance for this one !!
                                      • N Offline
                                        nektares
                                        Great Job! i must buy it when itΒ΄s ready!
                                        • N Offline
                                          notareal
                                          Looking good so far.
                                          • FrederikF Offline
                                            Frederik
                                            Godt gjort, Thomas...!
                                            I'm definitely going to purchase this one... πŸ˜„
                                            Cheers
                                            Kim Frederik
                                            • 12
                                            • 13
                                            • 1 / 13
