    [Plugin] Selection Toys
    594 Posts 121 Posters 381.0k Views 121 Watching
    • rami_lpmR Offline
      rami_lpm
      you'll be getting a lot of cookies for this one.
      • CadFatherC Offline
        CadFather
        Hi Thom, a late Thanks for this..
        is there a chance of having the context menu items available as toolbar choices?
        i can help with the icons if you need
        cheers
          The items for Group Copies and Instances?
            CadFather
            yes, comps and groups is a first choice. of course i shortcut them, which works fine, but there are lots of others:
            especially in the select submenu.
              I'll make note of that for the next version.
                CadFather
                Thanks Thom, and if i can help with anything let me know.
                  Cheers. I'll let you know if I do. Currently I'm working on a new feature. Will do the toolbar once that's done along with some improvement to the tool's descriptions.
                  • E Offline
                    e-anima
                    i do not know how to do the following. i have a cylinder and it is seperated in the middle by a loop of edges around. its like cut in the middle. how can i only select thes edges. its an edge ring. thank you
                    • free agentF Offline
                      free agent
                      Hi Thom
                      im getting this error on opening sketchup
                      Error Loading File tt_selection_toys.rb
                      No such file to load -- TT_Plugin_Manager/tt_plugin_manager.rb
                        Hi Thom
                        Did you download the required Plugin Manager package as well?
                          free agent
                          so ur saying read the instruction before posting random complaints?.... πŸ˜’
                            Me? I'd never! πŸ˜„
                              I know it's a bit annoying to install additional files - but there was so much work put into the UI Manager that I wanted to be able to reuse it.
                                • Fixed bug in select_same_direction_faces, select_parallel_faces, select_perpendicular_faces, select_same_area.
                                • Fixed bug in Select Only / Deselect Soft / Smooth Edges
                                • Added Command Cheat Sheet.
                                • Moved from Plugin_Manager to TT_Lib
                                  Nice update, thanks Thom πŸ‘
                                    pghstone83
                                    I downloaded the tt lib along with the selection tools file both that were both posted on the forum pgs. However, I am not able to get the selection tools toolbar in order to select the "loop" selection on the design program.
                                    Can you please help guide me as to how to make that happen?
                                      You must Enable it first - Tools -> Selection Toys - Enable Toolbar
                                      All commands are also available from the toolbar.
                                      Not sure which Loop method you refer to, but you got:
                                      Tools -> Selection Toys - Select Edge Loop
                                      and then you got the
                                      Right-Click on Edge -> Select - Quad-face Loop
                                        pghstone83
                                        My Tools button in the program does not have a "selection toys" button as an option to select in order to enable it.
                                          No Selection Toys under the Tools menu? that's very odd...
                                          how/where did you install the files?
                                          • EarthMoverE Offline
                                            EarthMover
                                            ThomThom,
                                            Is it possible to add an option to Select only "Outer Edges" and Deselect "Outer Edges"? Chris Fulmer wrote the code and mentioned in his post it may be better suited for your plugin.
                                            Do you think a "Select Connected by Orientation" for edges would be possible? Basically I'm asking for a loop select for edges. I know you were looking into it, just wondering if it would ever be possible, or if there are too many variables present to make it feasible to code.
                                            One other request, if doable, is a quad face loop select that would process multiple edges at once? I find this necessary if I am trying to select a quad loop on an extruded arc with multiple segments and multiple quad face loops. It would be nice to select one set of connected edges and select all their quad loops at the same time. Selection memory is a bit tedious.
                                            Thanks again for the plug...I love the new toolbar. Definitely owe you several dozen Cookies!!
                                            Content Creator at Skapeup
                                            • 11
                                            • 12
                                            • 29
                                            • 30
                                            • 10 / 30
