    [Plugin] Selection Toys
    594 Posts 121 Posters 528.2k Views 121 Watching
      I'll make note of that for the next version.
      • CadFatherC Offline
        CadFather
        Thanks Thom, and if i can help with anything let me know.
          Cheers. I'll let you know if I do. Currently I'm working on a new feature. Will do the toolbar once that's done along with some improvement to the tool's descriptions.
          • E Offline
            e-anima
            i do not know how to do the following. i have a cylinder and it is seperated in the middle by a loop of edges around. its like cut in the middle. how can i only select thes edges. its an edge ring. thank you
            • free agentF Offline
              free agent
              Hi Thom
              im getting this error on opening sketchup
              Error Loading File tt_selection_toys.rb
              No such file to load -- TT_Plugin_Manager/tt_plugin_manager.rb
              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                Hi Thom
                Did you download the required Plugin Manager package as well?
                  free agent
                  so ur saying read the instruction before posting random complaints?.... ๐Ÿ˜’
                    Me? I'd never! ๐Ÿ˜„
                      I know it's a bit annoying to install additional files - but there was so much work put into the UI Manager that I wanted to be able to reuse it.
                        • Fixed bug in select_same_direction_faces, select_parallel_faces, select_perpendicular_faces, select_same_area.
                        • Fixed bug in Select Only / Deselect Soft / Smooth Edges
                        • Added Command Cheat Sheet.
                        • Moved from Plugin_Manager to TT_Lib
                          Nice update, thanks Thom ๐Ÿ‘
                            pghstone83
                            I downloaded the tt lib along with the selection tools file both that were both posted on the forum pgs. However, I am not able to get the selection tools toolbar in order to select the "loop" selection on the design program.
                            Can you please help guide me as to how to make that happen?
                              You must Enable it first - Tools -> Selection Toys - Enable Toolbar
                              All commands are also available from the toolbar.
                              Not sure which Loop method you refer to, but you got:
                              Tools -> Selection Toys - Select Edge Loop
                              and then you got the
                              Right-Click on Edge -> Select - Quad-face Loop
                                pghstone83
                                My Tools button in the program does not have a "selection toys" button as an option to select in order to enable it.
                                  No Selection Toys under the Tools menu? that's very odd...
                                  how/where did you install the files?
                                  • EarthMoverE Offline
                                    EarthMover
                                    ThomThom,
                                    Is it possible to add an option to Select only "Outer Edges" and Deselect "Outer Edges"? Chris Fulmer wrote the code and mentioned in his post it may be better suited for your plugin.
                                    Do you think a "Select Connected by Orientation" for edges would be possible? Basically I'm asking for a loop select for edges. I know you were looking into it, just wondering if it would ever be possible, or if there are too many variables present to make it feasible to code.
                                    One other request, if doable, is a quad face loop select that would process multiple edges at once? I find this necessary if I am trying to select a quad loop on an extruded arc with multiple segments and multiple quad face loops. It would be nice to select one set of connected edges and select all their quad loops at the same time. Selection memory is a bit tedious.
                                    Thanks again for the plug...I love the new toolbar. Definitely owe you several dozen Cookies!!
                                    Content Creator at Skapeup
                                      Creepy! ... How did you know we where just talking about that?! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
                                      It's the "Orientation" part that get's a wee bit complicated to determine what is the user's expectation of correct orientation - as well as actually determining. Things is, would a loop select be ok if it selected the edges of co-planar faces? If they are not planar - then things start to become very odd to estimate...
                                      I think what I need to do with this edge loop thing is make it have more contraints. So what are the most typical types of selections and geometry? (if any)
                                      I'll add it to the list of things to look into.
                                        EarthMover
                                        Must be the sixth sense tingling!
                                        Regarding orientation for loop select....in most cases that I use it, the edges are coplanar, sharing a common axis. Perhaps one way would be to add an option to select connected edges by a given axis, to better define the orientation. This would handle most of my "loop" situations...although ideally a better method would be to glean the orientation of a selected edge and select all connected edges that are running closest to that orientation. You can look at the code here from a Select edges by Z script that I believe Jim helped me put together. (which I'm sure you already know as the code is simple) Only trouble with this one is that it accounts for the whole model so I usually have to group the area first and then I can select a loop by it's Z height. It might be something to consider adding, but also giving the choice to select connected by X & Y.
                                        selectedgesbyZ.rb
                                          pghstone83
                                          I sent the file to the plugins folder on my C drive and extracted it there.I also took in the TTLib folder that I thought I needed for the plugin to work. But when I open the TTLib file up there's another selection toys folder in there. I'm thankful for your for your patience. I'm new with this program.I've been trying to download this file for 3 days and I'm ready to lose it. Isn't the process to send these plugins to the plugins folder in C drive and simply hit extract and enable them in sketchup?
                                          • Chris FullmerC Offline
                                            The process is to extract the files to your SketchUp plugins folder. It doesn't matter where you save the .zip file as long as you can find it to extract from it. And then extract the contects into the plugins folder. Once you get how to do it, it is very simple and all other plugins work the same.
                                            • 11
                                            • 12
                                            • 29
                                            • 30
                                            • 10 / 30
