    [Plugin] Selection Toys
    594 Posts 121 Posters 552.6k Views 121 Watching
      @chris fullmer said:
      I also am thinking of other apps that make named lists, and you have to save and recall the selection through the list of named sets. But that seems difficult in SU to me I think. But maybe it would work. I supposed the list could be in a html dialog box and warn you if your selection set has changed wince it was created. And give the option to update the selection set, etc.
      I was thinking of adding selection tacks to the On Screen tool. As you modify/filter the selection you take snapshots. Autonamed, but you can set your own custom.
        and Thomas,
        v2 is looking sweet.. i haven't used the plugin in the past as i was a little overwhelmed by all the choices at first (and i was in the process of learning some other things at the time).. i'm giving it a legit shot now and it's great.
        thank you!
        Yea, it's grown a bit since its first appearance nearly a year ago. I find it difficult myself to make an organized overview in the main post.
        Hopefully the little cheat sheet can help.
        btw, the two functions I use the most is Select Only->Edges and Select Only->Faces. I've assigned them to Ctrl+1 and Ctrl+2 and it's probably the functions I use the most when I use SU.
          It's SU that automatically toggle the button down. Mechanism of assigning a Tool to a toolbar button.
          I don't really feel I want to add another toolbar button just to deactivate it. Personally I use hotkeys a lot and I always tap the Space bar to activate Select. One hand on the keyboard and one hand on the mouse. Rarely moving up to click toolbar buttons or menus. But I've observed at work that many work by point and click for nearly all their operations.
          Maybe an on screen button. Or make it so that if you click empty space it deactivates the tool.
          • JClementsJ
            JClements
            Thomas, shouldn't the Select Edge Loops icon in the Toolbar be a "Toggle button"...or add a "red" version of the icon to turn it off.
            Currently, you can turn it on by clicking it but clicking it again wont turn it off. User has to manually select SU's Select Tool.
            John
            • X
              xrok1
              YES!! please do.
              one more thing if i may. 😆 you know how if you use the eraser button everything you pass over highlights and if you select another tool before you let the button up... a selection toy like that would be great, i know there is:Capture.JPG but one that can select not just edges would be ☀
                ale one
                Very good script thomthom.
                Only i want to say what will be fantastic to add more functions to the loop selection tool,for the edges and faces. (i know it has been commented previously)
                thank you very much for your script.
                sorry for my bad inglish ;D
                • rami_lpmR
                  rami_lpm
                  you'll be getting a lot of cookies for this one.
                  • CadFatherC
                    CadFather
                    Hi Thom, a late Thanks for this..
                    is there a chance of having the context menu items available as toolbar choices?
                    i can help with the icons if you need
                    cheers
                      The items for Group Copies and Instances?
                      • CadFatherC
                        CadFather
                        yes, comps and groups is a first choice. of course i shortcut them, which works fine, but there are lots of others:
                        especially in the select submenu.
                          I'll make note of that for the next version.
                          • CadFatherC
                            CadFather
                            Thanks Thom, and if i can help with anything let me know.
                              Cheers. I'll let you know if I do. Currently I'm working on a new feature. Will do the toolbar once that's done along with some improvement to the tool's descriptions.
                              • E
                                e-anima
                                i do not know how to do the following. i have a cylinder and it is seperated in the middle by a loop of edges around. its like cut in the middle. how can i only select thes edges. its an edge ring. thank you
                                • free agentF
                                  free agent
                                  Hi Thom
                                  im getting this error on opening sketchup
                                  Error Loading File tt_selection_toys.rb
                                  No such file to load -- TT_Plugin_Manager/tt_plugin_manager.rb
                                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                    Hi Thom
                                    Did you download the required Plugin Manager package as well?
                                    • free agentF
                                      free agent
                                      so ur saying read the instruction before posting random complaints?.... 😒
                                        Me? I'd never! 😄
                                          I know it's a bit annoying to install additional files - but there was so much work put into the UI Manager that I wanted to be able to reuse it.
                                            • Fixed bug in select_same_direction_faces, select_parallel_faces, select_perpendicular_faces, select_same_area.
                                            • Fixed bug in Select Only / Deselect Soft / Smooth Edges
                                            • Added Command Cheat Sheet.
                                            • Moved from Plugin_Manager to TT_Lib
                                            • 11
                                            • 12
                                            • 29
                                            • 30
                                            • 10 / 30
