    Drop tool (forgotten)
    27 Posts 8 Posters 3.7k Views 8 Watching
      Chris Fullmer's Repeat Copy or Component onto Face or Kirill's Stick Group to Mesh?
        d12dozr
        Like this, right? That's the plugin I linked to above....shows up as 'Drop at Intersection' in right-click menu after selecting components...
        http://goo.gl/f7ooYh
          I have right Click "Drop at intersection" πŸ˜‰
          give me 5 minutes for refound the author πŸ˜„
          It's TBD ! β˜€
          drop15.rb
            tfdesign
            @solo said:
            I'm getting old and cannot remember.
            Yes, I'm afraid I suffer from this conditional also. 😲 😒
            I need the same plugin right now as well! Been thinking about how to do it all evening...but I have the "Google SketchUp for Site Design" book here....right lets see......hmm...the 'stamp tool'?......?
              I was confused by the Solo answer 😳
                tfdesign
                Ahh...hang on,...."Drop Ruby"? πŸ˜•
                  d12dozr
                  Ha, Tom, that's the book I referenced too....page 45 πŸ˜‰
                    tfdesign
                    Yep Pete, I think Pilou's nailed it! πŸ˜„
                    The 'Drop' ruby. Also named here by Daniel Tal. πŸ˜„
                      Spray Components by Didier Bur have inside Menu "Stay vertical" ! πŸ˜‰
                        tfdesign
                        πŸ˜†
                        Excellent! 😎 😎
                          d12dozr
                          ...'more curvy' terrain with 'drop at intersection' πŸ˜‰
                            tfdesign
                            So, is 'drop15' the same one?
                            edit; v1.5
                            • soloS Offline
                              πŸ‘
                              Thanks guys, After every new version of SU comes out I load ruby's as I need them and finding them can be difficult if you are an idiot like me and deleted SU 7 and all its files including ruby folder.
                                Seem you have possibility to Copy / Past some plugs from the old folder Plugins to the new πŸ’š
                                  d12dozr
                                  edit; v1.5
                                  The one on Smustard is version 1.52...so tiny bit newer
                                  • soloS Offline
                                    One issue...
                                    It drops right, but if you make a mistake and try to use undo, it undoes one at a tome, now if you have 200 poles it's a problem.
                                      tfdesign
                                      even if they're all one component?
                                      • soloS Offline
                                        If they are all one component then they do not follow the terrain, they need to be seperate components for the drop to work.
                                          d12dozr
                                          Maybe someone could PM TBD to request a fix?
                                          • utilerU Offline
                                            utiler
                                            @d12dozr said:
                                            edit; v1.5
                                            d12dozer, the one on smustard is version 1.500 it seems unless I'm looking in the wrong area...
                                            can you post the like?
                                            Just Curious...
