    Drop tool (forgotten)
    27 Posts 8 Posters 3.7k Views 8 Watching
      d12dozr
      ...'more curvy' terrain with 'drop at intersection' πŸ˜‰
      http://goo.gl/f7ooYh
        tfdesign
        So, is 'drop15' the same one?
        edit; v1.5
        • soloS Offline
          πŸ‘
          Thanks guys, After every new version of SU comes out I load ruby's as I need them and finding them can be difficult if you are an idiot like me and deleted SU 7 and all its files including ruby folder.
            Seem you have possibility to Copy / Past some plugs from the old folder Plugins to the new πŸ’š
              d12dozr
              edit; v1.5
              The one on Smustard is version 1.52...so tiny bit newer
              • soloS Offline
                One issue...
                It drops right, but if you make a mistake and try to use undo, it undoes one at a tome, now if you have 200 poles it's a problem.
                  tfdesign
                  even if they're all one component?
                  • soloS Offline
                    If they are all one component then they do not follow the terrain, they need to be seperate components for the drop to work.
                      d12dozr
                      Maybe someone could PM TBD to request a fix?
                      • utilerU Offline
                        utiler
                        @d12dozr said:
                        edit; v1.5
                        d12dozer, the one on smustard is version 1.500 it seems unless I'm looking in the wrong area...
                        can you post the like?
                        Just Curious...
                        • EarthMoverE Offline
                          EarthMover
                          Pete,
                          Check Thom's Raytracer tools as well. Should do what you need with a one step undo. http://forums.sketchucation.com/viewtopic.php?t=30509
                          Content Creator at Skapeup
                            d12dozr
                            I thought I got this from Smustard πŸ˜•
                            drop.rb
                            • Chris FullmerC Offline
                              It is a very old script that could use to be updated. Makig it undo everything in one ctrl-z would be really easy to do.
                              • 2 / 2
