    Drop tool (forgotten)
    27 Posts 8 Posters 3.0k Views 8 Watching
      I was confused by the Solo answer 😳
        tfdesign
        Ahh...hang on,...."Drop Ruby"? πŸ˜•
          d12dozr
          Ha, Tom, that's the book I referenced too....page 45 πŸ˜‰
          http://goo.gl/f7ooYh
            tfdesign
            Yep Pete, I think Pilou's nailed it! πŸ˜„
            The 'Drop' ruby. Also named here by Daniel Tal. πŸ˜„
              Spray Components by Didier Bur have inside Menu "Stay vertical" ! πŸ˜‰
                tfdesign
                πŸ˜†
                Excellent! 😎 😎
                  d12dozr
                  ...'more curvy' terrain with 'drop at intersection' πŸ˜‰
                    tfdesign
                    So, is 'drop15' the same one?
                    edit; v1.5
                    • soloS Offline
                      πŸ‘
                      Thanks guys, After every new version of SU comes out I load ruby's as I need them and finding them can be difficult if you are an idiot like me and deleted SU 7 and all its files including ruby folder.
                        Seem you have possibility to Copy / Past some plugs from the old folder Plugins to the new πŸ’š
                          d12dozr
                          edit; v1.5
                          The one on Smustard is version 1.52...so tiny bit newer
                          • soloS Offline
                            One issue...
                            It drops right, but if you make a mistake and try to use undo, it undoes one at a tome, now if you have 200 poles it's a problem.
                              tfdesign
                              even if they're all one component?
                              • soloS Offline
                                If they are all one component then they do not follow the terrain, they need to be seperate components for the drop to work.
                                  d12dozr
                                  Maybe someone could PM TBD to request a fix?
                                  • utilerU Offline
                                    utiler
                                    @d12dozr said:
                                    edit; v1.5
                                    d12dozer, the one on smustard is version 1.500 it seems unless I'm looking in the wrong area...
                                    can you post the like?
                                    Just Curious...
                                    • EarthMoverE Offline
                                      EarthMover
                                      Pete,
                                      Check Thom's Raytracer tools as well. Should do what you need with a one step undo. http://forums.sketchucation.com/viewtopic.php?t=30509
                                      Content Creator at Skapeup
                                        d12dozr
                                        I thought I got this from Smustard πŸ˜•
                                        drop.rb
                                        • Chris FullmerC Offline
                                          It is a very old script that could use to be updated. Makig it undo everything in one ctrl-z would be really easy to do.
