    Drop tool (forgotten)
    27 Posts 8 Posters 4.0k Views 8 Watching
      d12dozr
      Ha, Tom, that's the book I referenced too....page 45 πŸ˜‰
      http://goo.gl/f7ooYh
      • T
        tfdesign
        Yep Pete, I think Pilou's nailed it! πŸ˜„
        The 'Drop' ruby. Also named here by Daniel Tal. πŸ˜„
          Spray Components by Didier Bur have inside Menu "Stay vertical" ! πŸ˜‰
          • T
            tfdesign
            πŸ˜†
            Excellent! 😎 😎
              d12dozr
              ...'more curvy' terrain with 'drop at intersection' πŸ˜‰
              • T
                tfdesign
                So, is 'drop15' the same one?
                edit; v1.5
                • soloS
                  πŸ‘
                  Thanks guys, After every new version of SU comes out I load ruby's as I need them and finding them can be difficult if you are an idiot like me and deleted SU 7 and all its files including ruby folder.
                    Seem you have possibility to Copy / Past some plugs from the old folder Plugins to the new πŸ’š
                      d12dozr
                      edit; v1.5
                      The one on Smustard is version 1.52...so tiny bit newer
                      • soloS
                        One issue...
                        It drops right, but if you make a mistake and try to use undo, it undoes one at a tome, now if you have 200 poles it's a problem.
                        • T
                          tfdesign
                          even if they're all one component?
                          • soloS
                            If they are all one component then they do not follow the terrain, they need to be seperate components for the drop to work.
                              d12dozr
                              Maybe someone could PM TBD to request a fix?
                              • utilerU
                                utiler
                                @d12dozr said:
                                edit; v1.5
                                d12dozer, the one on smustard is version 1.500 it seems unless I'm looking in the wrong area...
                                can you post the like?
                                Just Curious...
                                • EarthMoverE
                                  EarthMover
                                  Pete,
                                  Check Thom's Raytracer tools as well. Should do what you need with a one step undo. http://forums.sketchucation.com/viewtopic.php?t=30509
                                  Content Creator at Skapeup
                                    d12dozr
                                    I thought I got this from Smustard πŸ˜•
                                    drop.rb
                                    • Chris FullmerC
                                      It is a very old script that could use to be updated. Makig it undo everything in one ctrl-z would be really easy to do.
