    Showing intersection lines
    26 Posts 8 Posters 2.7k Views 8 Watching
      The edge?
      You want to hide the edge?
        Looks like your Rim is the issue...
        Radial TA BF Goodrich j minus lug nuts.skp
        • hellnbakH Offline
          hellnbak
          @thomthom said:
          The edge?
          All I want to do is prevent the ugliness around the outer edge of the rim when it's viewed from any distance, at an angle. As I explained in my original post, it looks like it's got some sort of herringbone pattern, like you see on tv when somebody is wearing a suit with the wrong pattern on it, it seems to "shimmer". Geez, it's so difficult to explain, like trying to describe a smell, or a color. If you look at the model you can surely see what I'm referring to.
          • hellnbakH Offline
            hellnbak
            I've tried that, I've deleted the entire surface you're referring to, still there.
            Radial TA BF Goodrich j minus lug nuts a.skp
              The edge you point at in this image?
              http://forums.sketchucation.com/download/file.php?id=58468
              The appearance of that will depend on your graphic card and how well it anti-alias. If you will be seeing the rim from a distance the edge will be more distinct as the edge is always 1px thick regardless of your zoom level.
              If you have an object with lots of details that will be presented in a small size on screen you're best of hiding more edges.
              Edge Hidden
                Also - when you Export 2d it will look differently from what you see in screen - at least in terms of anti-aliasing.
                • jeff hammondJ Offline
                  the drawing is pretty sloppy. you have lines next to lines that should in fact be one line etc which is compounding the effects you're seeing.
                  that aside, you're asking to see a curved line made out of squares (pixels of your monitor).. something's got to give somewhere.. it's not going to happen. sorry.
                  some antialiasing settings can sort of reduce the effect but it's still going to be present no matter what you do or what software you're using.
                    Ok,
                    if you dissect the outer rim you'll see it's made of components. Good practice... πŸ‘
                    if you analyze those components you'll see they don't meet, but overlap. Bad practice... πŸ‘Ž
                    remember earlier i said face on face = z-fighting
                    These little errors occur everywhere and when you add them up you get visual trickery. Kinda Jeff's cool avatar
                    @jeff
                    you'll notice a new member to the bling club soon.... πŸ˜‰
                    • hellnbakH Offline
                      hellnbak
                      It will not be viewed at one particular distance, it's just that when it's viewed at a greater distance the problem occurs. As far as hiding the edges, for me that's not an option. The edges in this particular model play a big role in it's appearance, as I indicated when I posted my original question, wanting to know how to view more edges. When you hide all the edges, on this or any other SU model, it just looks so bland, so 2 dimensional. At least to me it does.
                        sweet!
                        • hellnbakH Offline
                          hellnbak
                          Probably none of my business, but what's a "bling club"?
                          • 2 / 2
