    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.4k Views 135 Watching
      SketchUpNoobie
      I know that. ๐Ÿ˜‰ Dunno' when I figured it out though. Probably while watching a tutorial or something. That's why I like watching tutorials even if they are on things I already know.
      SketchUpNoobie: the complete noob in all things SketchUp.
        Roger
        It seems that my Duh! moment was taking this long to find this discussion. I have always felt I was the lone idiot, but now I feel much better and much more informed.
        Thanks DUHsters.
        http://www.azcreative.com
        • Chris FullmerC Offline
          That is the point of the thread - we all feel like the lone idiot...until you post your stupidity publicly and find that many many other people had done, or are doing, the exact same thing. It's very cathartic ๐Ÿ˜„
          • david_hD Offline
            david_h
            Idiots are never alone.
            They travel in herds. . . .most frequently seen on the great American Freeway system.
              You should suffer fools gladly... one day you will be one of them!
              I once invented my great new tool for the context-menu that would select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
                Mine of the day ๐Ÿ’š (thx Regis)
                I have found that was a good idea ๐Ÿ’ญ
                Draw first the line then use
                but... ๐Ÿ’š
                you can also with only just enter in the VCB
                (whatever unities in activity)
                3.14cm
                31.4mm
                0.0314m
                ... (i am not very familiar with inch ๐Ÿ’š
                ๐Ÿ˜’
                  Add to the previous thread ๐Ÿ˜„
                  I reread the doc (that was written in small that you can enter measure in VCB with the Scale tool! ๐Ÿ˜ณ
                  And also a cool one (in the same doc)! ๐Ÿ’š
                  You can Press in the SAME TIME SHIFT AND CTRL with the Scale tool ! ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜ณ
                  For have a super scaling result! ๐Ÿ’š
                  • ToboboT Offline
                    Tobobo
                    One this week was more of a remembering than a Duh moment.
                    Using the Entity Ifon box you can increase the length of a line and No. of sides of a circle.
                    Toby
                    Philippians 4:13
                      @tobobo said:
                      ...No. of sides of a circle.
                      And a polygon and an arc...
                        In what side? Good or false? ๐Ÿ˜„
                        • spenceS Offline
                          spence
                          One of my many many "Duh" moments came when I found out that while using the Paint Bucket Tool you could hold down Shift to paint all that match or hold Ctrl to paint all connected. I use this often.
                          Boy I have learned a lot of new stuff from this thread ๐Ÿ˜„
                          Spence
                          • ToboboT Offline
                            Tobobo
                            The changes its length in the same direction it has been drawn. it has to be unattached at one end, and that is the end the lengthens or shortens.
                            Toby
                            Philippians 4:13
                              Jim
                              Has any one here also thought of compiling/organizing this thread into a more readable format? Wiki? Print?
                              • pyrolunaP Offline
                                pyroluna
                                well... there's a sketchup-wiki in Dutch... so... yay! for Dutch people
                                  Jim
                                  Today I learned you can use the arrow keys to precisely move the selection in Paint.NET. (Holding Ctrl moves it by 10 pixels.)
                                    I just realised it the other day myself, too. ๐Ÿ˜„
                                    • david_hD Offline
                                      david_h
                                      I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
                                      WHICH I NEVER USE BY THE WAY!!!!
                                      Hide Construction lines
                                      This is so humiliating. . .. ๐Ÿ˜ณ ๐Ÿ’š
                                      I'm okay now. . .
                                        Jim
                                        I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
                                          I had that same realization a couple of weeks ago. ๐Ÿ˜„
                                            @rv1974 said:
                                            If Thom is already here..
                                            Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                                            Great tool!
                                            Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
                                            btw, no need to doubleclick - single click is enough.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
