    Edges overlapping?
    11 Posts 7 Posters 1.1k Views 7 Watching
      Chad_UB
      Hi everyone. I've browsed these forums quite a bit and decided to join so that I can actually post.
      Anyways, I have a simple question. When there are edges drawn in my models, there is a thicker black line at the vertices. I turned off the show extensions option (I think that's what it's called), but that didn't have much of an effect. Is there a way to hide these lines without turning off edges? It's really annoying especially on 3D text where I want edges to actually appear.
      Chad
      • jim smithJ Offline
        jim smith
        might be a "style" thing. The default might be set on architectural design style. Just click on default or design style.
        If that isn't the solution - post a shot of the problem
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
          I think you're on it, Jim. At least one of the template choices includes endpoints.
          • Wo3DanW Offline
            Wo3Dan
            @chad_ub said:
            ... I turned off the show extensions option ...Is there a way to hide these lines without turning off edges?...
            You turned off extentions. Now you also need to turn off endpoints themselve.
            SU's mean menu Window > Styles > Edit > Edge Settings (first icon) > turn off endpoints.
              This is a basic 'Styles' issue...
              Open Menu > Window > Styles.
              Pick the Model Tab [small house icon].
              The current Style is shown.
              Edit it.
              Click the icon to edit Edge-Styles [1st?].
              Here you can choose many 'edge-options' - including not to have 'extensions', 'end-points', 'profiles' or even 'edges-at-all'...
              Save the settings.
              If you want to particular Style to kick in when you start a new SKP simply edit the Style in the Template SKP to be as you want - then every new SKP will start as you'd prefer...
                I don't really like thick profiles for instance but since newer SU versions do not display anything at curved surfaces with profiles off, I keep a 1 pixel profile. This does not have any effect on normally displayed edges but will give an outline to curved surfaces.
                  I don't like those thick edges or other things like endpoints at least when I am modeling, either. I do find having Profiles on and set to 1 is good for rounded things. Here's the settings I use for the edges.
                  http://farm5.static.flickr.com/4053/5151128982_71185dab9e.jpg
                    Displaying endpoints can be useful sometimes - just like hidden geometry - so I have a button for that in my custom toolbar, too. This way I can toggle it easily.
                      True, true.
                        Chad_UB
                        Thanks a lot guys! Such a huge help for such a simple problem.
                        • Chris FullmerC Offline
                          😄 yup, welcome to Sketchucation!
