    Valiarchitects - plugins
    94 Posts 42 Posters 30.6k Views 42 Watching
    • T
      tfdesign
      That Road plugin looks great! Perfect for making roads in Unity too. πŸ˜„
      OT; It was funny listening to some of the word pronunciations in the videos too- like "roof" pronounced "ruuf"- like a dogs bark! πŸ˜† I noticed that the TornadoTwins who make Unity instructional videos on YouTube also say "Hoover" instead of 'hover'. It's just an accent thing that I've always found fascinating (like the American accent, essentially being an Irish accent mixed with German- well that's what the American accent sounds like to me!).
      Great plugins. I will probably buy these- especially if the roof plugins can cope with buildings constructed with odd angled walls- like British Edwardian houses for eg.
      • C
        chuck vali
        Must be in your 60's?
        First computer class I ever took (1968). Took longer punching the cards and standing in line to submit them and to get the printout two days later than to figure how to write the 30 or-so line do-loop
        Close - I'm 52. I had similar experiences with card punching before I dropped the class. Plus, my professor said that computer programmers would never make any money.
        Have not tried Road King yet but will the road follow a preset path using standard highway slopes/grades and such or is it just a contour follower?
        Sorry, it doesn't do anything that fancy. I intended it as more of a schematic design tool. The script takes road center points, finds the corresponding terrain elevations and attempts to make a road with level cross slopes at those elevations. That's really all it does.
        Chuck
        • G
          grim
          chuck
          i have been trying out your instant road plugin prior to buying but seem to be haveing trouble obtaining the same results as the demo ( both in su 7.1 and 8 ) your comments please
          attached file shows the result
          instant road test.skp
          • C
            chuck vali
            Reply to Grim,
            The terrain has to be larger than the road plus the shoulder width. So I scaled up the terrain slightly to get it to work. But it made kind of a bumpy road. That's because the road precision was much tighter than the terrain spacing - which makes the road follow the coarse terrain. So in the next copy, I reduced the precision of the road by changing the "adjust number of curve segments" parameter from "3x" to "same as input" and the road was less bumpy. Try turning on hidden lines to see what I mean.
            As for "try before buy", all that pro does is let you make a few things wider - everything else is the same. So please see if you like it first. (And can figure out all my cryptic parameters)
            Chuck
            instant road test revised.skp
            • G
              grim
              thanks for the clarification chuck
              enjoy the wave's πŸ˜„
              • T
                tomislavm
                Thank You!
                • leedeeteeL
                  leedeetee
                  Amazing plugin. Thanks so much for this. I will no doubt be buying the Pro version, once I've got to grips with the free version!
                  I had a play with it last night before bed adn was then dreamign abotu it!!! 🀣
                    Ands43
                    Is it possible to create a cross gabled roof as in my attachement, using this software as when I have tried I end up with one roof higher than the other. i'm still using the free version for the time being.
                    • C
                      chuck vali
                      Tails,
                      It looks like the slope on the one gable is different than that of the other. Is that the intent? The script can make intersecting gables, but the roof slopes must be the same for both parts of the roof. I spent some time trying to make the script capable of generating different roof portions with different slopes, but I kept ending up with a really complicated user interface. So I gave it up, assuming that I would just tell people to generate different sloped parts in separate pieces.
                      Chuck
                      • F
                        fossa
                        Chuck:
                        First of all great work, I will be buying all three in the near future.
                        Do you plan on updating the scripts with more features, and if so how long before a new purchase would be required.
                        • soloS
                          Chuck,
                          How do I solve the gap between road and ground, I fear it may be because of SU size limitation, but when I opt out of curb and even set hieght to 0, I get gaps.
                          • C
                            chuck vali
                            @solo said:
                            Chuck,
                            Solo,
                            Would you mind sending me the .skp so I can try to figure out what's happening?
                            Thanks,
                            Chuck
                            • C
                              chuck vali
                              @solo said:
                              Chuck,
                              Solo,
                              Disregard my last message - I think I know what it is. Did you set the road thickness to between -1" and +1" and if so does it work when you set road thickness outside that range?
                              Chuck
                              • T
                                tspco
                                Chuck, nicely done, on the instant roof RB, I downloaded it and installed it in SU7, drew a quick model, then rendered it KT, and the roof doesn't leak (light that is). That is one problem I have had in the past, I usually can get it fixed but it cuts into my "play time".
                                Thanks again for a great plug!
                                SU make 2017, /Twilight Render Hobby
                                Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                • C
                                  chuck vali
                                  @solo said:
                                  Chuck,
                                  It's not a SU size limitation. The road thickness must be >= 1" or <= -1", otherwise a gap will occur. If you need the road surface flush with surrounding terrain, you can generate the road at some arbitrary thickness, select the top road surface and move it down. (It has the exact same perimeter as the hole in the terrain, so it will fit).
                                  Chuck
                                  • soloS
                                    Thanks Chuck.
                                    I had to select it and use move tool to get it flush. Entering 0" does not get accepted I noticed, it automatically defaults to 1/2", no problem as there is a work around.
                                    • V
                                      vidy
                                      @dtrarch said:
                                      New question:
                                      Does it work with SU 7.1 free
                                      or just 8.0 Pro? ❓
                                      kind of having the same problem here, im using su 7.1
                                      please could it be checked Chuck or this plugins only for su 8?
                                      thank you,
                                      VD
                                      still so much to learn..
                                      • KrisidiousK
                                        Krisidious
                                        I'm using it on 7.1 no issues yet. none that were not just me not configuring or setting up the plugin properly.
                                        By: Kristoff Rand
                                        • V
                                          vidy
                                          hi krist,
                                          probably could provide a step by step just in writing for this plugin to work or how it work, actually for the roof i have no problem, but when i try to follow solo's image to create a road, it just nothing happen..
                                          thanks,
                                          • KrisidiousK
                                            Krisidious
                                            there are a bunch of tutorials on Chuck's site... have you seen them yet?
                                            404 Not Found
                                            (www.valiarchitects.com)
                                            By: Kristoff Rand
                                            • 2 / 5
