    Valiarchitects - plugins
    94 Posts 42 Posters 25.7k Views 42 Watching
      Hi Chuck,
      Welcome to SCF, and what an introduction. Great toolset. I've been a long time user of 1001bits and this is like it long lost sister.
      Congrats
      Rich
        chuck vali
        Hi everybody!
        "Instant" has kind of been a joke around my house recently too. With me as the butt. I've actually been working on the instantCash program since Fortran days, but I could only ever get it to decrement - never increment.
        Here's a link to a pdf where I attempt to show what most of the roof, eave, fascia, rafter and hip parameters do: http://www.valiarchitects.com/sites/default/files/tutorials/pdf/Roof-parameters.pdf
        Thanks for all the comments.
        Chuck
        • JClementsJ Offline
          JClements
          Fortran.
          Must be in your 60's?
          First computer class I ever took (1968). Took longer punching the cards and standing in line to submit them and to get the printout two days later than to figure how to write the 30 or-so line do-loop.
          Congratulations of some very useful scripts, Chuck.
          Regards, John
            dtrarch
            Hi Chuck
            WOW πŸ‘
            Question ? β˜€
            Have not tried Road King yet but will the road follow a preset path using standard highway slopes/grades and such or is it just a contour follower? ❓
            Really slick stuff and thanks for such good docs too.
            dtr
              dtrarch
              New question:
              Does it work with SU 7.1 free
              or just 8.0 Pro? ❓
              Is path hard coded to standard SU install?
              If so how about an install that has a path option?
              Road does not work for me with SU 7.1 free std path and does not show in Plugins for non standard SU 8 Pro path.
              thx
              dtr
                Ands43
                Thanks for your help chuck!! Much appreciated.
                  tfdesign
                  That Road plugin looks great! Perfect for making roads in Unity too. πŸ˜„
                  OT; It was funny listening to some of the word pronunciations in the videos too- like "roof" pronounced "ruuf"- like a dogs bark! πŸ˜† I noticed that the TornadoTwins who make Unity instructional videos on YouTube also say "Hoover" instead of 'hover'. It's just an accent thing that I've always found fascinating (like the American accent, essentially being an Irish accent mixed with German- well that's what the American accent sounds like to me!).
                  Great plugins. I will probably buy these- especially if the roof plugins can cope with buildings constructed with odd angled walls- like British Edwardian houses for eg.
                    chuck vali
                    Close - I'm 52. I had similar experiences with card punching before I dropped the class. Plus, my professor said that computer programmers would never make any money.
                    Sorry, it doesn't do anything that fancy. I intended it as more of a schematic design tool. The script takes road center points, finds the corresponding terrain elevations and attempts to make a road with level cross slopes at those elevations. That's really all it does.
                    Chuck
                      grim
                      chuck
                      i have been trying out your instant road plugin prior to buying but seem to be haveing trouble obtaining the same results as the demo ( both in su 7.1 and 8 ) your comments please
                      attached file shows the result
                      instant road test.skp
                        chuck vali
                        Reply to Grim,
                        The terrain has to be larger than the road plus the shoulder width. So I scaled up the terrain slightly to get it to work. But it made kind of a bumpy road. That's because the road precision was much tighter than the terrain spacing - which makes the road follow the coarse terrain. So in the next copy, I reduced the precision of the road by changing the "adjust number of curve segments" parameter from "3x" to "same as input" and the road was less bumpy. Try turning on hidden lines to see what I mean.
                        As for "try before buy", all that pro does is let you make a few things wider - everything else is the same. So please see if you like it first. (And can figure out all my cryptic parameters)
                        Chuck
                        instant road test revised.skp
                          grim
                          thanks for the clarification chuck
                          enjoy the wave's πŸ˜„
                            tomislavm
                            Thank You!
                            • leedeeteeL Offline
                              leedeetee
                              Amazing plugin. Thanks so much for this. I will no doubt be buying the Pro version, once I've got to grips with the free version!
                              I had a play with it last night before bed adn was then dreamign abotu it!!! 🀣
                                Ands43
                                Is it possible to create a cross gabled roof as in my attachement, using this software as when I have tried I end up with one roof higher than the other. i'm still using the free version for the time being.
                                  chuck vali
                                  Tails,
                                  It looks like the slope on the one gable is different than that of the other. Is that the intent? The script can make intersecting gables, but the roof slopes must be the same for both parts of the roof. I spent some time trying to make the script capable of generating different roof portions with different slopes, but I kept ending up with a really complicated user interface. So I gave it up, assuming that I would just tell people to generate different sloped parts in separate pieces.
                                  Chuck
                                  • F Offline
                                    fossa
                                    Chuck:
                                    First of all great work, I will be buying all three in the near future.
                                    Do you plan on updating the scripts with more features, and if so how long before a new purchase would be required.
                                    • soloS Offline
                                      Chuck,
                                      How do I solve the gap between road and ground, I fear it may be because of SU size limitation, but when I opt out of curb and even set hieght to 0, I get gaps.
                                        chuck vali
                                        @solo said:
                                        Chuck,
                                        Solo,
                                        Would you mind sending me the .skp so I can try to figure out what's happening?
                                        Thanks,
                                        Chuck
                                          chuck vali
                                          @solo said:
                                          Chuck,
                                          Solo,
                                          Disregard my last message - I think I know what it is. Did you set the road thickness to between -1" and +1" and if so does it work when you set road thickness outside that range?
                                          Chuck
                                            tspco
                                            Chuck, nicely done, on the instant roof RB, I downloaded it and installed it in SU7, drew a quick model, then rendered it KT, and the roof doesn't leak (light that is). That is one problem I have had in the past, I usually can get it fixed but it cuts into my "play time".
                                            Thanks again for a great plug!
                                            SU make 2017, /Twilight Render Hobby
                                            Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                            • 2 / 5
