    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.1k Views 76 Watching
    • JClementsJ Offline
      JClements
      TIG:
      Is the result you wanted when erasing coplanar edges?
      John
      P.S.
      JSClements is a temp login until I can get JClements restored.
      Is this the result you wanted when deleting coplanar edges.skp
        cyan.archnet
        really SUPERB plugin, THANKS A LOT!
          Perfect zoom this time ๐Ÿ‘
          • TIGT Online
            Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
            Some rare coplanar edge erasure errors have now been trapped...
            • TIGT Online
              TIG:
              John
              P.S.
              Obviously not ! ๐Ÿ˜
              I will check on why this might be happening... I thought such things had all got trapped... watch out for an update !!!
                Seems you will be quiet only when your true sweep 2 rails will be born ๐Ÿ˜„
                Because the "stay parallel orientation" of curves is sometimes annoying for real forms ๐Ÿ˜‰
                • TIGT Online
                  Pilou, patience ! ๐ŸŽ‰
                    ๐Ÿ˜„
                    It's soon holiday so September will be Christmas surprise ๐Ÿ’š
                    • F Offline
                      Fletch
                      First, TIG, thank you so much for this awesome plugin! I've been begging Didier for years to write a Follow Me tool for Edges for a long time.
                      The only issue is that the edge remains in its original orientation as it follows the path, it does not re-orient to be perpendicualar to the edge line, or at least keep the original angle between them.
                      Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example.
                      if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
                      Fletch
                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                        I have ask also Didier with his new Extrude along a vector for have the same fonction but...
                        ๐Ÿ’š
                        http://forums.sketchucation.com/download/file.php?id=29592&t=1
                        • TIGT Online
                          @fletch said:
                          First, TIG, thank you so much for this awesome plugin! ...
                          Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example... if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
                          You are correct it is 'extrude edges *by*edges' and does NOT extrude alongedges as in the followme mode... It's not exactly what you want.
                          However, I am looking at another tool 'extrude edge by rails' - you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release...
                            japanNuke
                            my jaw just hit the ground ๐Ÿ˜ฎ
                            thank you tiger-sama
                            %(#BFBFBF)[be cool
                            be bad]
                              tigerobj
                              cool hihi
                              • F Offline
                                Fletch
                                However, I am looking at another tool ... watch for first beta release...
                                ๐Ÿ˜„
                                will be looking, thanks, TIG!
                                Fletch
                                  JClements
                                  Version 7.
                                  Seems to do the trick.
                                  Thank you, SIR.
                                  • jwlyon1J Offline
                                    jwlyon1
                                    So great! So many uses! This is one of my new favorite plugins!
                                    Macbook Pro/ iMac
                                    OSX 10.7.2 Sketchup 8
                                    rogue-z is here!
                                    • TIGT Online
                                      Here's v1.8
                                      Significant speed improvements in Orienting and Triangulation...
                                        BorgMan
                                        @tig said:
                                        [...]However, I am looking at another tool 'extrude edge by rails' - you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release...
                                        Great bird of the galaxy, you're actually taking a go at that? I really don't know where I would be if it weren't for you guys with a SketchUppers best friend in the form of ruby's ^_^
                                        More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                        You've gotta love Slivers.
                                        • TIGT Online
                                          If fact. ExtrudeEdgesByRails.rb is now progressing well... Expect a release within the month !
                                          It already 'works'. BUT I am trying to make it 'foolproof' - as it's possible [easy] to select a profile and 2 rails that cause all sorts of generation complications - I am trying to trap this out...
                                          • plot-parisP Offline
                                            plot-paris
                                            that is fantastic news, TIG. can't wait to try it out! ๐ŸŽ‰
                                            • 5 / 10
