    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 242.4k Views 76 Watching
      THX! Very reactive! ๐Ÿ˜Ž ๐Ÿ‘
      Edit ๐Ÿ˜„
      Seems there is something wrong in the "Zoom" ๐Ÿ˜‰
      That don't work ๐Ÿ˜ฎ
      zoom out must be made before the first dialog box "Orient faces"
      Without that zoom don't work even at the end ๐Ÿ˜„
      (I have of course the 1.5)
      zoom.skp
        Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
        It fixes a glitch with large mesh group results not zooming properly so that you can see them all...
        The way it works is that it selects the group, 'zooms selected' and then removes group from selection - fine for modest sized meshes BUT if the group is too large SUp hasn't found the selection to 'zoom to' before the selection is cleared... so I've put the 'remove from selection' part after the first dialog so it has time !
        • JClementsJ
          JClements
          TIG:
          Is the result you wanted when erasing coplanar edges?
          John
          P.S.
          JSClements is a temp login until I can get JClements restored.
          Is this the result you wanted when deleting coplanar edges.skp
          • C
            cyan.archnet
            really SUPERB plugin, THANKS A LOT!
              Perfect zoom this time ๐Ÿ‘
                Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                Some rare coplanar edge erasure errors have now been trapped...
                  TIG:
                  John
                  P.S.
                  Obviously not ! ๐Ÿ˜
                  I will check on why this might be happening... I thought such things had all got trapped... watch out for an update !!!
                    Seems you will be quiet only when your true sweep 2 rails will be born ๐Ÿ˜„
                    Because the "stay parallel orientation" of curves is sometimes annoying for real forms ๐Ÿ˜‰
                      Pilou, patience ! ๐ŸŽ‰
                        ๐Ÿ˜„
                        It's soon holiday so September will be Christmas surprise ๐Ÿ’š
                        • FletchF
                          Fletch
                          First, TIG, thank you so much for this awesome plugin! I've been begging Didier for years to write a Follow Me tool for Edges for a long time.
                          The only issue is that the edge remains in its original orientation as it follows the path, it does not re-orient to be perpendicualar to the edge line, or at least keep the original angle between them.
                          Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example.
                          if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
                          Fletch
                            I have ask also Didier with his new Extrude along a vector for have the same fonction but...
                            ๐Ÿ’š
                            http://forums.sketchucation.com/download/file.php?id=29592&t=1
                              @fletch said:
                              First, TIG, thank you so much for this awesome plugin! ...
                              Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example... if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
                              You are correct it is 'extrude edges *by*edges' and does NOT extrude alongedges as in the followme mode... It's not exactly what you want.
                              However, I am looking at another tool 'extrude edge by rails' - you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release...
                                japanNuke
                                my jaw just hit the ground ๐Ÿ˜ฎ
                                thank you tiger-sama
                                %(#BFBFBF)[be cool
                                be bad]
                                • T
                                  tigerobj
                                  cool hihi
                                  • FletchF
                                    Fletch
                                    However, I am looking at another tool ... watch for first beta release...
                                    ๐Ÿ˜„
                                    will be looking, thanks, TIG!
                                    Fletch
                                    • JClementsJ
                                      JClements
                                      Version 7.
                                      Seems to do the trick.
                                      Thank you, SIR.
                                      • jwlyon1J
                                        jwlyon1
                                        So great! So many uses! This is one of my new favorite plugins!
                                        Macbook Pro/ iMac
                                        OSX 10.7.2 Sketchup 8
                                        rogue-z is here!
                                          Here's v1.8
                                          Significant speed improvements in Orienting and Triangulation...
                                          • B
                                            BorgMan
                                            Great bird of the galaxy, you're actually taking a go at that? I really don't know where I would be if it weren't for you guys with a SketchUppers best friend in the form of ruby's ^_^
                                            More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                            You've gotta love Slivers.
                                            • 5 / 10
