    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 242.4k Views 76 Watching
      I have ask also Didier with his new Extrude along a vector for have the same fonction but...
      ๐Ÿ’š
      http://forums.sketchucation.com/download/file.php?id=29592&t=1
        @fletch said:
        First, TIG, thank you so much for this awesome plugin! ...
        The only issue is that the edge remains in its original orientation as it follows the path, it does not re-orient to be perpendicualar to the edge line, or at least keep the original angle between them.
        Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example... if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
        You are correct it is 'extrude edges *by*edges' and does NOT extrude alongedges as in the followme mode... It's not exactly what you want.
        However, I am looking at another tool 'extrude edge by rails' - you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release...
          japanNuke
          my jaw just hit the ground ๐Ÿ˜ฎ
          thank you tiger-sama
          %(#BFBFBF)[be cool
          be bad]
          • T
            tigerobj
            cool hihi
            • FletchF
              Fletch
              However, I am looking at another tool ... watch for first beta release...
              ๐Ÿ˜„
              will be looking, thanks, TIG!
              Fletch
              • JClementsJ
                JClements
                Version 7.
                Seems to do the trick.
                Thank you, SIR.
                • jwlyon1J
                  jwlyon1
                  So great! So many uses! This is one of my new favorite plugins!
                  Macbook Pro/ iMac
                  OSX 10.7.2 Sketchup 8
                  rogue-z is here!
                    Here's v1.8
                    Significant speed improvements in Orienting and Triangulation...
                    http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                    • B
                      BorgMan
                      Great bird of the galaxy, you're actually taking a go at that? I really don't know where I would be if it weren't for you guys with a SketchUppers best friend in the form of ruby's ^_^
                      More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                      You've gotta love Slivers.
                        If fact. ExtrudeEdgesByRails.rb is now progressing well... Expect a release within the month !
                        It already 'works'. BUT I am trying to make it 'foolproof' - as it's possible [easy] to select a profile and 2 rails that cause all sorts of generation complications - I am trying to trap this out...
                        • plot-parisP
                          plot-paris
                          that is fantastic news, TIG. can't wait to try it out! ๐ŸŽ‰
                          • I
                            iamarchitecture
                            Many thanks...first post btw.;.
                            • N
                              Nick1
                              Hi all,
                              I could be blind but where can I find or download these scripts?
                              TIA,
                              Nick
                              I think I found it. Thanks again.
                                @nick1 said:
                                Hi all,
                                TIA,
                                Nick
                                It's the first post in the thread... ๐Ÿ’ญ
                                • P
                                  pr0bka
                                  Tig, is the extrude edges by rails going to be something that has the ability to morph 2 different polylines into each other across another polyline? Much like a cross between Chris Fullmers loft plugin and your extrude edges by edges?
                                  Btw, just curious, how long does it usually take to program something like this? I'm amazed at all your and everyone else's work!!!! Thanks again.
                                  • C
                                    chango70
                                    Hows it coming? I have a feeling this is one of those plugin that will really make organic (along with others ofcourse) modelling easy in SU.
                                    • jeff hammondJ
                                      yes, the others ๐Ÿ˜„
                                      i'm probably just dreaming that there's an easier way to draw this in SU but it sure would be nice!
                                      • C
                                        CosmicFlow
                                        Thanks for the upload. I don't know what I'm going to do with it yet. Maybe I'll do some blobitecture for my final project in 3 weeks ๐Ÿ˜„
                                          Extrude Edges by Rails is now out and can probably do this more efficiently ?
                                          • K
                                            kwistenbiebel
                                            Hi TIG, I am new to this thread...somehow totally missed it.
                                            This plugin looks awesome so I tried it.
                                            However when activating it, it remains unresponsive.
                                            I drew two Bezier curves, exploded each,made them into 2 groups and then used the plugin...
                                            At the bottom of the SU screen it says "multiplying edges" but nothing happens. As soon as I start moving my mouse the text disappears but nothing was created.
                                            Am I doing something wrong?
                                            • 5 / 10
