[Plugin] extrudeEdgesByEdges.rb
TIG:
Is the result you wanted when erasing coplanar edges?
John
P.S.
JSClements is a temp login until I can get JClements restored.Obviously not !
I will check on why this might be happening... I thought such things had all got trapped... watch out for an update !!! -
Seems you will be quiet only when your true sweep 2 rails will be born
Because the "stay parallel orientation" of curves is sometimes annoying for real forms
Pilou, patience !
It's soon holiday so September will be Christmas surprise
First, TIG, thank you so much for this awesome plugin! I've been begging Didier for years to write a Follow Me tool for Edges for a long time.
The only issue is that the edge remains in its original orientation as it follows the path, it does not re-orient to be perpendicualar to the edge line, or at least keep the original angle between them.
Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example.
if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
I have ask also Didier with his new Extrude along a vector for have the same fonction but...
@fletch said:
First, TIG, thank you so much for this awesome plugin! ...
Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example... if this tool is not intended to do what I'm looking for here, please ignore this post. thx.You are correct it is
'extrude edges *by*edges'and does NOT extrude alongedges as in the followme mode... It's not exactly what you want.
However, I am looking at another tool'extrude edge by rails'- you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release... -
my jaw just hit the ground
thank you tiger-sama -
cool hihi
@tig said:
You are correct it is'extrude edges *by*edges'and does NOT extrude alongedges as in the followme mode... It's not exactly what you want.
However, I am looking at another tool ... watch for first beta release...
will be looking, thanks, TIG! -
Version 7.
Seems to do the trick.
Thank you, SIR.
So great! So many uses! This is one of my new favorite plugins!
Here's v1.8
Significant speed improvements in Orienting and Triangulation...
http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 -
'extrude edge by rails'- you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release...Great bird of the galaxy, you're actually taking a go at that? I really don't know where I would be if it weren't for you guys with a SketchUppers best friend in the form of ruby's ^_^
If fact. ExtrudeEdgesByRails.rb is now progressing well... Expect a release within the month !
It already 'works'. BUT I am trying to make it 'foolproof' - as it's possible [easy] to select a profile and 2 rails that cause all sorts of generation complications - I am trying to trap this out...
that is fantastic news, TIG. can't wait to try it out!
Many thanks...first post btw.;.
Hi all,
I could be blind but where can I find or download these scripts?
TIA,
Nick
I think I found it. Thanks again. -
@nick1 said:
Hi all,
TIA,
Nick
I think I found it. Thanks again.It's the first post in the thread...
Tig, is the extrude edges by rails going to be something that has the ability to morph 2 different polylines into each other across another polyline? Much like a cross between Chris Fullmers loft plugin and your extrude edges by edges?
Btw, just curious, how long does it usually take to program something like this? I'm amazed at all your and everyone else's work!!!! Thanks again.
With your input, this post could be even better ๐
