    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 238.2k Views 76 Watching
      Seems you will be quiet only when your true sweep 2 rails will be born ๐Ÿ˜„
      Because the "stay parallel orientation" of curves is sometimes annoying for real forms ๐Ÿ˜‰
        Pilou, patience ! ๐ŸŽ‰
          ๐Ÿ˜„
          It's soon holiday so September will be Christmas surprise ๐Ÿ’š
          • FletchF Offline
            Fletch
            First, TIG, thank you so much for this awesome plugin! I've been begging Didier for years to write a Follow Me tool for Edges for a long time.
            The only issue is that the edge remains in its original orientation as it follows the path, it does not re-orient to be perpendicualar to the edge line, or at least keep the original angle between them.
            Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example.
            if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
            Fletch
              I have ask also Didier with his new Extrude along a vector for have the same fonction but...
              ๐Ÿ’š
              http://forums.sketchucation.com/download/file.php?id=29592&t=1
                @fletch said:
                First, TIG, thank you so much for this awesome plugin! ...
                Please see attached to see what I mean, I am looking for a tool to create something like shown on the right of this image example... if this tool is not intended to do what I'm looking for here, please ignore this post. thx.
                You are correct it is 'extrude edges *by*edges' and does NOT extrude alongedges as in the followme mode... It's not exactly what you want.
                However, I am looking at another tool 'extrude edge by rails' - you'll select a profile and two 'rail' edge-sets [or just one 'rail' and the other will be inferred as being like the first but at the other end of the profile] and then it extrudes the profile along the edges in a followme manner; these rails can be different shapes and orientations and a complex surface mesh is made from the three in combination... It's WIP at the moment... watch for first beta release...
                  japanNuke
                  my jaw just hit the ground ๐Ÿ˜ฎ
                  thank you tiger-sama
                  %(#BFBFBF)[be cool
                  be bad]
                    tigerobj
                    cool hihi
                    • FletchF Offline
                      Fletch
                      However, I am looking at another tool ... watch for first beta release...
                      ๐Ÿ˜„
                      will be looking, thanks, TIG!
                      Fletch
                      • JClementsJ Offline
                        JClements
                        Version 7.
                        Seems to do the trick.
                        Thank you, SIR.
                        • jwlyon1J Offline
                          jwlyon1
                          So great! So many uses! This is one of my new favorite plugins!
                          Macbook Pro/ iMac
                          OSX 10.7.2 Sketchup 8
                          rogue-z is here!
                            Here's v1.8
                            Significant speed improvements in Orienting and Triangulation...
                            http://forums.sketchucation.com/viewtopic.php?p=166780#p166780
                              BorgMan
                              Great bird of the galaxy, you're actually taking a go at that? I really don't know where I would be if it weren't for you guys with a SketchUppers best friend in the form of ruby's ^_^
                              More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                              You've gotta love Slivers.
                                If fact. ExtrudeEdgesByRails.rb is now progressing well... Expect a release within the month !
                                It already 'works'. BUT I am trying to make it 'foolproof' - as it's possible [easy] to select a profile and 2 rails that cause all sorts of generation complications - I am trying to trap this out...
                                • plot-parisP Offline
                                  plot-paris
                                  that is fantastic news, TIG. can't wait to try it out! ๐ŸŽ‰
                                  • I Offline
                                    iamarchitecture
                                    Many thanks...first post btw.;.
                                    • N Offline
                                      Nick1
                                      Hi all,
                                      I could be blind but where can I find or download these scripts?
                                      TIA,
                                      Nick
                                      I think I found it. Thanks again.
                                        @nick1 said:
                                        Hi all,
                                        TIA,
                                        Nick
                                        It's the first post in the thread... ๐Ÿ’ญ
                                          pr0bka
                                          Tig, is the extrude edges by rails going to be something that has the ability to morph 2 different polylines into each other across another polyline? Much like a cross between Chris Fullmers loft plugin and your extrude edges by edges?
                                          Btw, just curious, how long does it usually take to program something like this? I'm amazed at all your and everyone else's work!!!! Thanks again.
                                            chango70
                                            Hows it coming? I have a feeling this is one of those plugin that will really make organic (along with others ofcourse) modelling easy in SU.
                                            • 5 / 10
