    [Plugin] 2D Tools
    791 Posts 178 Posters 649.8k Views 177 Watching
    • CadFatherC Offline
      CadFather
      icons updated as well (thanks TIG)
      Icons.zip
        Thanks - I'll include them for the next update - meanwhile anyone who wants them now... please replace the original Icons with these...
          Here's v5.0 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
          The db arguments etc are parenthesized in (). Various minor glitches in text etc have been addressed. The ES lingvo & help files have also been updated etc - many thanks to Defisto for his nit-picking that goaded me into the update! CadFather's new toolbar button icon set is also include if you want to swap over to that...
            define
            @tig said:
            Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
            hello TIG, thx for your 2d-toolset...I'm using it all the time and would'nt know how to get along without it.
            But I have to second ThomThom with his question, if one 'sotospeak' could make the 2dtools work with
            your 'work-planes' too? This would make it into something even more versatile.
            You answered ThomThom with a link - I can't however figure out what you are pointing at.
            If there's already a means to switch the 2dtools z-axis to any 'temporarily active one' please
            give me a hint.
            thx a lot for the 2dtools and the 'workplane-plug' and all the other plugs as well
              Ben Ritter
              I can use the hatching option only once, thereafter, I the hatch selection window doesn't open. Tried it with SU7 and SU8, same issue.
              Any suggestions?
                Ben Ritter
                Sorry for the bother. I'm short on memory and lazy. Just looked at some previous posts and found the answer.
                • EarthMoverE Offline
                  EarthMover
                  This would in fact be quite redundant. The work planes are used in a similar manner to the 2D tools, as they create a "shield" to prevent the inferencing of the native tools to the geometry on the opposite side of the plane. You can draw directly on it as it's a locked group and delete it at will. The 2D tools do much the same except they are restricted to the X,Y axis for 2D drawing, but still allow you set the Z, which creates an invisble 2D work plane on that height. The work plane plugin allows similar restriction, only it's not restricted to X,Y only and it works with the native toolset. You could technically set a work plan on the x,y axis at a Z height and use the native tools to draw in restricted 2D. Using the 2D tools to go the other direction would negate them from being 2D at all.
                  Content Creator at Skapeup
                    I find that the native tools - especially the line tool all to often pick inference in the Z-Axis - so when I think I've drawn a shape on a plane I've in fact drawn a 3d shape.
                    That's why it'd be nice to have a tool that restricted drawing to the arbitrary set plane.
                      razer
                      Hey guys me again. Im looking for something that would lock in my masurement's when I create a 2d rectangle, for instance I want the height and width to be free to move but not my length I want it to stay a certain mesurement I want that to stay the same no matter where my mouse is could 2d tools do this?
                        DIEGO-RODRIGUEZ
                        hi tig.
                        a question.
                        You Can add this utility to function chamfer and fillet?
                        The idea Would Be to chamfer or fillet + welding in a single step
                        maybe:
                        if we hold down the Ctrl key> chamfer or fillet + welding
                        if not press the ctrl> single chamfer or fillet.
                        is it possible?
                        Greetings
                          Diego
                          Your idea is feasible... however, I feel that with the virtually indispensable 'weld.rb' loaded, with a shortcut to say 'J'oin, you could simply select the three pieces, press 'J' and it'll weld them into a single polyline/curve anyway...
                          • N Offline
                            NikosID
                            Hi Tig
                            I am sorry to bother you with something that may sound so simple but I am trying to download your plug-in 2D tools and I always get comets like “time out”....basically i don't manage to download it. Is it because my internet connection speed in Indonesia is too slow, is it that I do something wrong. If you have a suggestion I will be glad to hear from you. Thank you in advance for taking time to answer.
                            NikosID
                              @nikosid said:
                              Hi Tig
                              NikosID
                              I have sent a PM with a cut-down set of files - for example I suspect you won't want the Spanish Help files! You should be able to download these in 'parts'...
                                maxosmedia
                                SU7, SU8. MacOSX10.6.5 MacBookPro 15" C2D 2,16
                                  Looks like incorrectly installed to me. I'd delete all files related to 2D Tools from the Plugins directory and reinstall correctly. You should end up with something like this in the Plugins folder.
                                    maxosmedia
                                    Thank Dave R!
                                    I looked the SU plug-ins directory. The problem was in the strange document, called "2D%23loader.rb". After his removal,
                                    problem has been fixed!
                                      You should have a file in the 2D Tools folder called 2D#Loader. I think the '#' got changed to '%23'.
                                        maxosmedia
                                        2D#Loader.rb
                                        It is this document creates this bug. Tested now
                                          That file should be inside the 2D Tools folder.
                                          • elmerE Offline
                                            elmer
                                            Hi Tig,
                                            First of all thank you for your great work with plugins.
                                            I just download 2D Tools but can't find the toolbar, what's wrong with me?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 39
                                            • 40
                                            • 16 / 40
