    [Plugin] Mirror
    211 Posts 72 Posters 478.4k Views 72 Watching
    • CAntonisC
      CAntonis
      Works great TiG!
      I have been using previous version from the context menu, but this is much easier!
      Thank U
      • KrisidiousK
        Krisidious
        I've noticed with Mirror I can only mirror geometry or groups... components bug-splat me every time.
        I've learned not to mirror components and I've not had any issues since. so now should it be able to do components?
        Post Script...
        shouldn't there be a website somewhere that someone grateful soul like myself could drop a pound or two in the box for you Tig?
        By: Kristoff Rand
          Post Script...
          It exists - PayPal = info @ revitrev.org πŸ˜„
          Mirroring Instances should be relative Bugsplat free by now - try grouping them first ? then explode afterwards...
          • JClementsJ
            JClements
            " BUT the main change is that on a PC it will now automatically 'roll-up' any open 'Outliner' window temporarily while it's Mirroring, to avoid the known issue of Sketchup's 'Bugsplats'."
            Excellent! Should be a part of all rubies where the Outliner would cause problems.
            Perhaps it could be some kind of a global script, would that make sense?
            • jeff hammondJ
              on mac, that already exists.. it's called 'Avoid_Outliner_at_all_Costs.rb' πŸ˜„
              here's a transparent png for anyone that wants to prettify their toolbar without the white square.
                DIEGO-RODRIGUEZ
                TIG. a question.
                it is normal that when I run the tool ouliner mirror with open, sketchup generate a 'Bugsplats' and close?
                  Diego
                  Your question is a little 'ambiguous' - however, I have tested all permutations and with me [Vista SUp v7/8] I get no such issues.
                  This is what should happen when using the tool...
                  When you have a selection and run 'Mirror', then you pick point[s] and it mirrors the selection, finally asking if you want to erase the original etc.
                  If there is no selection when you run 'Mirror' you are told so, and it stops.
                  On a PC there are now additional safeguards against 'Outliner' generated BugSplats...
                  When you run 'Mirror' AND the 'Outliner' is open AND it is 'rolled-down', the 'Outliner' window is automatically 'rolled-up', then Mirror continues and you pick point[s] etc - on completion the 'Outliner' is 'rolled-down' back to its original state.
                  When you run 'Mirror' AND the 'Outliner' is open BUT it is already 'rolled-up', then nothing is done to it, then Mirror continues and you pick point[s] etc, to completion.
                  When you open/close the 'Outliner' during normal working it should have no affect on the 'Mirror' tool.
                  Have you extracted all of the required files into the '../Plugins/' folder?
                  I appreciate that if you are 'splatting' the Console is unlikely to be very useful... but can you get it to fail with the Ruby Console open and do you get any error messages?
                    DIEGO-RODRIGUEZ
                    this is the error.
                    I use
                    windows xp sp3, in Spanish. sketchup sketchup 8 in Spanish and 7 in Spanish
                    in the two versions generated BugSplats.
                    the image is made with sketchup 8.
                    although sketchup 7, BugSplats generates but does not generate error reporting in the console ruby
                      The rolled-down 'Outliner' WILL often cause a splat, that is why the new version tries to set it to 'roll-up' - however I notice you have it 'docked' that might be stopping the 'roll-up' - try having the 'Outliner' NOT docked with the others and see if that splats too... If it does the recommendation stands don't have the Outliner open/rolled-down while using tools that process groups - as it can 'splat'!
                      I've no idea what the error message means - it must be another script that gets involved with components - quietly_force_sync_mats_cb just - is not in my Sketchup files [I 'grepped' them all]
                        Jim
                        Does it bugsplat if you use the 2nd parameter for start_operation?
                          DIEGO-RODRIGUEZ
                          Tig.
                          the error in the ruby console, is generated by file called RubyWinFunc.so, using the Vray render engine.
                          and
                          Sketchup is closed only when the mirror and duplicate the components / groups.
                          However if only mirror the components / groups (not duplicate) sketchup is not closed.
                          By far the best solution is to have the closed ouliner
                          and a question.
                          when applied to a curved mirror. duplicated curve is exploited.
                          can be solved?
                            Diego
                            I only rarely happens to me - usually a Curve is kept intact...
                            If you know you have Curves and experience the problem then you could manually Group the Selection before Mirroring it.
                            I don't know how to stop the rare 'raw' curve exploding glitch - the method used is basically "the selection is grouped, the group is copied, scaled -1 [to 'mirror' it] and then the original group might be deleted, then the group is exploded so the selection is back as it was but now 'mirrored'.
                            A Curve shouldn't 'explode' as it's container group explodes but just sometimes it does!
                            I was aware of the glitch but in a few tests just now I can't get it to reproduce - could you post a small SKP with a failing example ?
                              DIEGO-RODRIGUEZ
                              tig. is a very strange error.
                              sometimes it generates and sometimes not.
                              I have not found a pattern of regular behavior
                              • B
                                bd99
                                thankkkkkkkkkkkkkk
                                • T
                                  tfdesign
                                  Tig, I use the Flip Along tool a lot of the time. I also watched a SketchUp tutorial with an official Google instructor saying that he didn't quite get it (flip along). I don't understand what there is that's not to get? How does your Mirror plugin differ or improve what's already available?
                                  Tom
                                  • GaieusG
                                    With the flip along tool, you can flip along one of the main axes (or those of groups/components) only. This plugin lets you mirror in a bunch of different ways, too.
                                      As Gai explained... the built in 'Flip' mirrors around the model's axes.
                                      This is also similar to using Scale with '-1', where the 'mirroring' is limited to three directions too.
                                      The Mirror tool allows you to mirror around a point, line or plane depending whether you pick 1, 2 or 3 points.
                                      The most usual is around the plane from 3 points - that way you can Mirror about any plane, not just the axial planes and the mirrored version is related to the plane in the reverse manner to the original selection. To do it with Flip/Scale would involve one or more Rotate steps too.
                                      The other benefit of Mirror is that [like CAD tools] on completion of the mirroring you can choose to keep or delete the original selection - useful when modeling in symmetrical parts etc as the 'copy' part is built-in for you...
                                      • GaieusG
                                        Although this is not hard with the native tools either;
                                        1. Copy the "to-be-mirrored" entity
                                        2. Do the mirroring (flip or scale)
                                        3. Paste in place the original entity
                                          But awkward with non-axial flips...
                                          • T
                                            tfdesign
                                            I think it's got to be the sado-masochistic mathematician in me! (incidentally, my old man is a Cambridge-educated topologist! πŸ˜‰ ) I like that "now how can I do this without a plugin?". πŸ˜† Sounds good Tig. Thanks for the reply. I'll try and get round to having a go with this tool some time in the not too distant future. πŸ˜„
                                            Meanwhile, I have a table to build! πŸ˜‰
                                            Tom
                                            • 11
                                            • 1 / 11
