    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
      dedmin
      And Rhino maps the image as a texture
      • N
        notareal
        Nice one! I can imagine that one day this will be in need.
          Dedmin, that looks nice.
          I did make the heighfield map in SketchUp so I know that part can be done. Here's the mesh from which I made the map.
          http://farm5.static.flickr.com/4118/4791556894_9724ee2004_z.jpg
            dedmin
            Sure - I mean the plugin. Can that plugin make so small mesh from an image without scaling? Looks good Dave πŸ‘
            By the way, did You notice that Layout 3 can now paste Excel tables - very handy!
            • shuraS
              shura
              Jeff, that concentric wave looks great!
              Thomas, sorry but I won't be able to get out of Berlin atm. We are preparing to move to a new appartment with my son being only six weeks old, and Munich is 600km from here... 😒
              Enjoy your time there - and don't forget that not all of us germs wear leather pants and drink beer until they pass out. πŸ˜†
              alex
                What?! I've been lied to!! πŸ˜„
                  yeah, it works in sketchup..
                  tt's script scales everything to a square so i made the mistake of adding more black for an overall 500x500 px (4times the recommended resolution of 250x250)..
                  it came in at a modest 1.25 million entities πŸ˜„
                  I'll update it with a tool for placing the mesh in the model, with correction aspect ratio and let you define a height - basically let you draw a bounding box.
                  Maybe even with an option to sample less pixels.
                    Or... Maybe interpolate pixels... Though - the same could be done by the user by just scaling down the image...
                      Dedmin, thanks. Since I haven't been able to do it yet, I don't know but I fully expect I'd have to scale the mesh to the right size. Looks like Jeff managed it, though.
                      As to the excel tables into LO, yes. I did see that. You can't do anything about formatting once it is in, though. Oh well, maybe in LO4.
                      • shuraS
                        shura
                        just used an alpha map and deleted the lower part of the mesh, then flattened it. not talking about quality, but at least it looks like some sort of image tracing...
                        • ken28875K
                          ken28875
                          Wow! 😲 😲
                          You keep on amazing me with your plugins, Thomas! You're the man.
                          Thank you very much,
                          _KN
                          Follow Your Dreams.
                          • Chris FullmerC
                            @thomthom said:
                            Test with simple displacement map:
                            MMMmmmm, a plugin that makes chocolate bars. I'm hungry now!
                              πŸ˜„
                              • MALAISEM
                                MALAISE
                                ThomThom , for your own knowledge, you should get advantages by visiting ImageJ community (OpenSource)http://www.google.fr/url?sa=t&source=web&cd=1&ved=0CBUQFjAA&url=http%3A%2F%2Frsbweb.nih.gov%2Fij%2F&rct=j&q=ImageJ&ei=ujqnTJXjIZGp4AbwxvGjDQ&usg=AFQjCNGnkzWAmC5t2IbtD4C8ayw1R0v7tg&sig2=e2-bW7zDggSXIeVI7vPRbA&cad=rja. They work around scientific pictures, and all the ways to extract informations .
                                Thank you really very much for all the plugins you give us.
                                MALAISE
                                La Connaissance n'a de valeur que partagΓ©e
                                  Except with very small BMP files, I don't seem to have any luck. Even with a small BMP file it takes a long time to process but that could just be my computer.
                                  Coen's comment though is intriguing. I was thinking this plugin could be a neat way to get line drawings into SketchUp. I made the attached line drawing as a quick test and got the second image as a result. I inverted the image and got the results in the third image. I wonder if it would be possible to have a control to somehow limit the range in the gray scale. Perhaps any RGB value less than, say, 250,250,250 gets read as 0,0,0? Or perhaps no height is assigned? Perhaps it isn't possible but I wonder.
                                    Making Knuckle-Dusters Dave?
                                      Maybe I should. πŸ˜„ I was just doodling on the pad using AutoDesk Sketchbook.
                                        It's technical possible to read values lower than 250 as 0, but I don't quite get why?
                                        Though you can do it in PS (or similar) by adjusting the Levels.)
                                        I have an idea of how to make the mesh less spiky though, but it needs some experimenting.
                                          I was just thinking that setting some limit so that everything is either black or white and not shades of gray would get rid of the spikes.
                                          Would it be possible to work things so that a face is created only if the value is less than some set point (250,250,250?) and the face is always at Z=0? Delete coplanar edges between faces and you'd have a raster to SKP converter.
                                            I like that idea πŸ‘
                                            Kind of Footprint or Ink Stamp tool, lots of uses for it too!
                                            • 13
                                            • 14
                                            • 3 / 14
