    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 433.3k Views 75 Watching
      Yea - the last texture I tested was 512x512 - heavy mesh. And I'd forgotten that Autosave was on - every 5 mins. x_X
        dedmin
          dedmin
          • shuraS Offline
            shura
            Why don't I get the Curve Simplification to work?
              hm... possibly you have a version where it failed on closed loops. I might not have uploaded a corrected version...
              • david_hD Offline
                david_h
                So I notice these wonderful meshes created. How is one controlling the height of the extrusion?
                  pichuneke
                  The pieces on the roof (above the pediment) are made with your plugin 😄
                  http://farm5.static.flickr.com/4103/5053994977_c27d104e30_z.jpg
                  Reconstrucción del Templo de Artemis Agrotera 4 by Egocentrico, on Flickr
                  Click here to see it in bigger size (1024 px):
                  All sizes | Reconstrucción del Templo de Artemis Agrotera 4 | Flickr - Photo Sharing!
                  The safest and most inclusive global community of photography enthusiasts. The best place for inspiration, connection, and sharing!
                  (www.flickr.com)
                  Forgive my spanglish...
                    Ghalko
                    So I read the posts and then thought nothing of trying a 2048x2048 heightmap produced by L3DT (terrain generating program.) 😲 Maybe I should try a bit smaller at first. Then I won't just freeze sketchup and make my patience run out... 😕
                    I will try with a smaller (much smaller) one first and post the results.
                    Bryan
                    Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
                    • soloS Offline
                      Color, the darker the black and brighter the white will produce the greatest crests and troughs.
                        Ghalko
                        After letting a 384x384 (meters) heightmap simmer:
                        Yey!
                        • david_hD Offline
                          david_h
                          I get that easy enough. its all based on contrast. . .so One must go into PhoShop and manipulate and lessen those contrasts before putting it into the plugin? Because when I down loaded the scrolly motif lintel thing, I got all kinds of mess. I just couldn't get my model to look like others were doing. . .
                          I'll keep playing with it.
                          • jeff hammondJ Offline
                            David,
                            Use the scale tool to compress it vertically.
                            • david_hD Offline
                              david_h
                              oh well. . . there's one for the duh thread.
                              Thx 😳
                                With version 0.2.0 you specify the height your self - either by using the cursor or entering a length in the VCB.
                                • spenceS Offline
                                  spence
                                  thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE!
                                  Spence
                                  • david_hD Offline
                                    david_h
                                    Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. 💚
                                      thohan
                                      Thank you for this great plugin. 😄
                                      I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
                                      I think with some more effort, one can achieve much better results.
                                      http://img43.imageshack.us/img43/8434/smalltest.png
                                      It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
                                      • jamalitoJ Offline
                                        jamalito
                                        wow wow wow
                                        where have you been ? man
                                        I looking for such as plug-in
                                        thank you so so much thomthom
                                        you helped me
                                        because I have a lot pictures I want to do it
                                        Albert Einstein:
                                        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                          Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
                                          Nice coin by the way. 😄
                                            marcomartim
                                            This plugin is great!
                                            I use Sketchup with Phlatscript plugin to generate code G (2.5 D) to use on my CNC Router, lack a 3D plugin for editing G code on Sketchup.
                                            For 3D and 4D, still use the Artcam,; Now with this plugin can create 3D models from photos, right in Sketchup.
                                            Thank you.
                                            • 13
                                            • 14
                                            • 4 / 14
