    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 470.0k Views 75 Watching
    • david_hD Offline
      david_h
      @solo said:
      Color, the darker the black and brighter the white will produce the greatest crests and troughs.
      I get that easy enough. its all based on contrast. . .so One must go into PhoShop and manipulate and lessen those contrasts before putting it into the plugin? Because when I down loaded the scrolly motif lintel thing, I got all kinds of mess. I just couldn't get my model to look like others were doing. . .
      I'll keep playing with it.
      • jeff hammondJ Offline
        David,
        Use the scale tool to compress it vertically.
        • david_hD Offline
          david_h
          oh well. . . there's one for the duh thread.
          Thx 😳
            With version 0.2.0 you specify the height your self - either by using the cursor or entering a length in the VCB.
            • spenceS Offline
              spence
              thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE!
              Spence
              • david_hD Offline
                david_h
                Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. πŸ’š
                  thohan
                  Thank you for this great plugin. πŸ˜„
                  I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
                  I think with some more effort, one can achieve much better results.
                  http://img43.imageshack.us/img43/8434/smalltest.png
                  It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
                  • jamalitoJ Offline
                    jamalito
                    wow wow wow
                    where have you been ? man
                    I looking for such as plug-in
                    thank you so so much thomthom
                    you helped me
                    because I have a lot pictures I want to do it
                    Albert Einstein:
                    ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                      Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
                      Nice coin by the way. πŸ˜„
                        marcomartim
                        This plugin is great!
                        I use Sketchup with Phlatscript plugin to generate code G (2.5 D) to use on my CNC Router, lack a 3D plugin for editing G code on Sketchup.
                        For 3D and 4D, still use the Artcam,; Now with this plugin can create 3D models from photos, right in Sketchup.
                        Thank you.
                          Christmended
                          Thanks for the awesome plugin!
                          Here is a test result I did.
                            Shaun, that almost looks like a lithophane. Cool.
                            • H Offline
                              Heven7_floor
                              Great Plug-in, thank your gift to make SU plugin to display the thing happen πŸ‘ πŸ‘ πŸ‘
                                pichuneke
                                The plugin works with bump mapping. I have no idea about what I am saying, but could it work with normal and displacement maps?
                                I have no idea about programming, except an unfinished Interactive Fiction game 5 years ago in the "popular" inform 6 language 😲 πŸ˜† πŸ˜†
                                Forgive my spanglish...
                                  Displacement maps are the same as bump maps - grayscale heightmaps. As for normal maps, I don't really know how they work...
                                    pichuneke
                                    I have found a lot about normal maps here:
                                    Google
                                    (www.google.com)
                                    but it's written in chinese, or C++ ... πŸ˜† I don't know if it may interest you, I was spending my time a bit (as I don't understand a single word πŸ˜„ )
                                    • arquitectomaracuchoA Offline
                                      arquitectomaracucho
                                      excuse my English, Greetings πŸ‘Š
                                      Thomtom greetings, very good tool for many functions πŸ‘ . be possible to add option mesh, giving a percentage between simple and complex mesh, thanks πŸ‘
                                        That would be simply resizing the bitmap down - which is much more efficient to do in your favourite image editor than via a Ruby plugin.
                                          Scott M
                                          Just downloaded the plugin an gave it a try.I folowed the promp but nothing is showing up it is saying generating mesh but continues to thnink as if unresponsive.Is my system just too slow or am I doing something wrong. Could someone outline the process.The images you guys posted look great.I allso operate a cnc and would lke very much to use this plugin.
                                          https://www.youtube.com/user/ecabinetstips
                                            What image are you feeding it?
                                            How large?
                                            If you keep the Ruby Console open, do you get error messages?
                                            • 13
                                            • 14
                                            • 4 / 14
