    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 508.1k Views 75 Watching
      dedmin
      Yes, true. I just wanted to test it - the file is 105 MB 🤣
        Yea - the last texture I tested was 512x512 - heavy mesh. And I'd forgotten that Autosave was on - every 5 mins. x_X
          dedmin
            dedmin
            • shuraS Offline
              shura
              Why don't I get the Curve Simplification to work?
                hm... possibly you have a version where it failed on closed loops. I might not have uploaded a corrected version...
                • david_hD Offline
                  david_h
                  So I notice these wonderful meshes created. How is one controlling the height of the extrusion?
                    pichuneke
                    The pieces on the roof (above the pediment) are made with your plugin 😄
                    http://farm5.static.flickr.com/4103/5053994977_c27d104e30_z.jpg
                    Reconstrucción del Templo de Artemis Agrotera 4 by Egocentrico, on Flickr
                    Click here to see it in bigger size (1024 px):
                    ERROR: The request could not be satisfied
                    (www.flickr.com)
                    Forgive my spanglish...
                      Ghalko
                      So I read the posts and then thought nothing of trying a 2048x2048 heightmap produced by L3DT (terrain generating program.) 😲 Maybe I should try a bit smaller at first. Then I won't just freeze sketchup and make my patience run out... 😕
                      I will try with a smaller (much smaller) one first and post the results.
                      Bryan
                      Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
                      • soloS Offline
                        Color, the darker the black and brighter the white will produce the greatest crests and troughs.
                          Ghalko
                          After letting a 384x384 (meters) heightmap simmer:
                          Yey!
                          • david_hD Offline
                            david_h
                            I get that easy enough. its all based on contrast. . .so One must go into PhoShop and manipulate and lessen those contrasts before putting it into the plugin? Because when I down loaded the scrolly motif lintel thing, I got all kinds of mess. I just couldn't get my model to look like others were doing. . .
                            I'll keep playing with it.
                            • jeff hammondJ Offline
                              David,
                              Use the scale tool to compress it vertically.
                              • david_hD Offline
                                david_h
                                oh well. . . there's one for the duh thread.
                                Thx 😳
                                  With version 0.2.0 you specify the height your self - either by using the cursor or entering a length in the VCB.
                                  • spenceS Offline
                                    spence
                                    thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE!
                                    Spence
                                    • david_hD Offline
                                      david_h
                                      Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. 💚
                                        thohan
                                        Thank you for this great plugin. 😄
                                        I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
                                        I think with some more effort, one can achieve much better results.
                                        http://img43.imageshack.us/img43/8434/smalltest.png
                                        It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
                                        • jamalitoJ Offline
                                          jamalito
                                          wow wow wow
                                          where have you been ? man
                                          I looking for such as plug-in
                                          thank you so so much thomthom
                                          you helped me
                                          because I have a lot pictures I want to do it
                                          Albert Einstein:
                                          ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                            Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
                                            Nice coin by the way. 😄
                                            • 13
                                            • 14
                                            • 4 / 14
