    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
    • G
      Ghalko
      So I read the posts and then thought nothing of trying a 2048x2048 heightmap produced by L3DT (terrain generating program.) 😲 Maybe I should try a bit smaller at first. Then I won't just freeze sketchup and make my patience run out... πŸ˜•
      I will try with a smaller (much smaller) one first and post the results.
      Bryan
      Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
      • soloS
        So I notice these wonderful meshes created. How is one controlling the height of the extrusion?
        Color, the darker the black and brighter the white will produce the greatest crests and troughs.
        • G
          Ghalko
          After letting a 384x384 (meters) heightmap simmer:
          Yey!
          • david_hD
            david_h
            I get that easy enough. its all based on contrast. . .so One must go into PhoShop and manipulate and lessen those contrasts before putting it into the plugin? Because when I down loaded the scrolly motif lintel thing, I got all kinds of mess. I just couldn't get my model to look like others were doing. . .
            I'll keep playing with it.
            • jeff hammondJ
              David,
              Use the scale tool to compress it vertically.
              • david_hD
                david_h
                oh well. . . there's one for the duh thread.
                Thx 😳
                  With version 0.2.0 you specify the height your self - either by using the cursor or entering a length in the VCB.
                  • spenceS
                    spence
                    thomthom, this is very cool. I can hardly believe you got this to work. I use this in Eon-Software's Vue and love it, now that it can be done on SU is incredible. VERY NICELY DONE!
                    Spence
                    • david_hD
                      david_h
                      Pretty cool little Plugin. thanks for the update. . .. makes it much easier for us idiots. πŸ’š
                      • T
                        thohan
                        Thank you for this great plugin. πŸ˜„
                        I did a quick test with it on a picture of a friend of mine with minimal pre-processing (just making the background black) and placed it on a norwegian coin.
                        I think with some more effort, one can achieve much better results.
                        http://img43.imageshack.us/img43/8434/smalltest.png
                        It do however generate a mesh that is very big. I suppose merging the squares (?) which lie next to each other in the same height, would make it lighter?
                        • jamalitoJ
                          jamalito
                          wow wow wow
                          where have you been ? man
                          I looking for such as plug-in
                          thank you so so much thomthom
                          you helped me
                          because I have a lot pictures I want to do it
                          Albert Einstein:
                          ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                            Yea, it produces a very dense mesh - You can use my Cleanup script to remove edges between coplanar faces.
                            Nice coin by the way. πŸ˜„
                              marcomartim
                              This plugin is great!
                              I use Sketchup with Phlatscript plugin to generate code G (2.5 D) to use on my CNC Router, lack a 3D plugin for editing G code on Sketchup.
                              For 3D and 4D, still use the Artcam,; Now with this plugin can create 3D models from photos, right in Sketchup.
                              Thank you.
                              • C
                                Christmended
                                Thanks for the awesome plugin!
                                Here is a test result I did.
                                  Shaun, that almost looks like a lithophane. Cool.
                                  • H
                                    Heven7_floor
                                    Great Plug-in, thank your gift to make SU plugin to display the thing happen πŸ‘ πŸ‘ πŸ‘
                                    • P
                                      pichuneke
                                      The plugin works with bump mapping. I have no idea about what I am saying, but could it work with normal and displacement maps?
                                      I have no idea about programming, except an unfinished Interactive Fiction game 5 years ago in the "popular" inform 6 language 😲 πŸ˜† πŸ˜†
                                      Forgive my spanglish...
                                        Displacement maps are the same as bump maps - grayscale heightmaps. As for normal maps, I don't really know how they work...
                                        • P
                                          pichuneke
                                          I have found a lot about normal maps here:
                                          http://www.google.com/search?hl=es&q=+site:gamedev.net+normal+map+algorithm&sa=X&ei=zwXHTLXUK4WO4Aa2yNXtDw&ved=0CBsQrQIwAA
                                          but it's written in chinese, or C++ ... πŸ˜† I don't know if it may interest you, I was spending my time a bit (as I don't understand a single word πŸ˜„ )
                                          • arquitectomaracuchoA
                                            arquitectomaracucho
                                            excuse my English, Greetings πŸ‘Š
                                            Thomtom greetings, very good tool for many functions πŸ‘ . be possible to add option mesh, giving a percentage between simple and complex mesh, thanks πŸ‘
                                            • 13
                                            • 14
                                            • 4 / 14
