    [Plugin] Work Plane
    183 Posts 32 Posters 157.7k Views 32 Watching
      DIEGO-RODRIGUEZ
      thanks tig.
      excellent option, rotated 90 with the Tab key. and the option to delete
        So to recap Pilou's technique for adding a WorkPlane to a whole [rectangular] face with desired divisions of say 7 & 5...
        First make a new WorkPlane over the face so it's aligned/snapped onto it,.
        Right-click to open the Settings dialog and enter 7 and 5 units, then grids at 1 and 1 units.
        On completion right-click 'unlock' [or shortcut it - I have K and shift+K for locK/unlocK] and move it by a corner onto a face's corner,
        Use 'Scale' on the WorkPlane and resize it in the X then Y dimensions to cover whole face.
        'Lock' it if desired.
        Now you have a WorkPlane that is an exact fit over the face with proportional divisions...
        Use those to place or draw over as needed etc...Capture.PNG It's an alternative to using Move+Ctrl copy with \n in both directions on guides or lines...
          Can you try Grow with WorkPlane, I have always a big Splatch ๐Ÿ˜ฎ
          You are 'unlocking' it first ?
          It works 'splatlessly' for me...
          • B
            Ben Ritter
            TIG, thank you very much for sharing your work. ๐Ÿ‘ ๐Ÿ‘
            With most of the plugins, it's obvious for me to see the application. In what ways do you see this application being used?
            Thanks. Ben
              WorkPlane will have lots of applications - many I haven't even thought of!
              For example, snapping objects/geometry onto a plane that's parallel to a face.plane but not necessarily overlapping it, or even just any notional plane from 3 picked points, that's not one of the standard 'views'.
              A WorkPlane also 'slices' other geometry easily when used in conjunction with with intersect....
              • jeff hammondJ
                @earthmover said:
                Work planes are also great for intersect slicing!
                โ˜€
                  Can you try Grow with Work plane, I have always a big Splat ๐Ÿ˜ฎ
                  I want copy *10 the "Work plane"
                  I just make *10 on X axis , 2 as X spacing, all the rest = 0
                  works fine for -2 as x spacing โ˜€
                  all is created as I see it on the Outliner, but at the end Splat
                  Edit Splat for 2 et -2 ! So very curious ๐Ÿ˜ฒ
                  wplane.skp
                    @ Tig you can use only Scale for make the fit on the face ๐Ÿ˜‰
                    • CadFatherC
                      CadFather
                      this is turning into a fun ruby too - what about if the c-lines were shorter? (one could always create infinite ones from them)
                        No problem for make copy move multiple โ˜€
                        But always Splate
                        V6 with grow + Work plane don't works ๐Ÿ˜ž
                        V7 with grow + Work plane
                        works with half : following X spacing is negative or not ๐Ÿ˜ฎsplat1.png
                        • kenK
                          ken
                          The added function of the tab, rotating the plane 90 degrees, and the content menu deleting is to perfect. Glad to see this plugin has generated some activity.
                          Thanks TIG
                          • W
                            watkins
                            Dear TIG,
                            As CADFather suggested, shorter clines would be good. I haven't tried this plugin yet, but it strikes me that it would make an excellent alignment feature too, particularly if having made the feature one could drag it to a point while retaining the alignment with the plane.
                            Thank you for all your hard work.
                            Kind regards,
                            Bob
                            • CadFatherC
                              CadFather
                              very interesting Ken....made me smile.. ..'half of infinity'.. ..gonna use that in class! ๐Ÿ˜ฒ
                              • kenK
                                ken
                                Maybe, the clines could be 1/2 of infinite. That way the ends would show up on my large monitor.
                                Ken
                                Darn, don't know how to bring a smilie into this message. So just imagine a smiling face.
                                Cadfather, fast fingers, slow eyes.
                                • EarthMoverE
                                  EarthMover
                                  Quick video I made showing a little of WorkPlane.rb in action -
                                  YouTube - Workplane.rb - A Sketchup plugin
                                  by AprC8Life
                                  [flash=480,385:87khe87q]http://www.youtube.com/v/xf56s_rKguw?fs=1&hl=en_US[/flash:87khe87q]
                                  Content Creator at Skapeup
                                  • CadFatherC
                                    CadFather
                                    great clip Adam.. is that you playing too?
                                    • EarthMoverE
                                      EarthMover
                                      The music? No. The video is done with all generic stuff that comes with Camtasia 7. Took about 10 minutes to edit and upload straight from Camtasia to Youtube. Then with Jim's SCF youtube bookmark, it embedded quick and easy. I figured I'd upgrade my Camtasia and drop my Screencast.com subscription, as it's a hassle. Glad you like the demo vid. It's always a big pain to try and draw details onto a busy surface, but with this plugin, it's a breeze!
                                        DIEGO-RODRIGUEZ
                                        tig.
                                        may add an option to enable / disable the grid?
                                        • EarthMoverE
                                          EarthMover
                                          Diego, if you right click before you draw the work plane, there is a grid on/off toggle.
                                            @Adam - Thanks a lot! An interesting demo - so it's also useful if you are modeling prehistoric reptiles ! ๐Ÿ˜‰
                                            @Diego - To change the WorkPlane Settings - i.e. the overall size or whether it has a grid [and what size that will be if it does] right-click in empty space anytime the tool is active and a dialog appears you can reset the values [if Grid? is true a second dialog will ask for those values] - see the notes in the first post...
                                            • 2 / 10
