    [Plugin] Work Plane
    183 Posts 32 Posters 133.1k Views 32 Watching
      Perpendicular face tool by Chris Fullmer thx Jeff ๐Ÿ˜Ž
      Ahhhhhhhh! Never thought (or remembered) to click on the segment ๐Ÿ˜ฎ ๐Ÿ‘
      That was not explicit due this alert message! ๐Ÿ’š
        Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
        The 'Tab' key now toggles the new WorkPlane between 'planar to the 3picked points' and 'perpendicular to plane of the 3 picked points [pt1/pt2 set the axial alignment], then you press <Enter> or double-click to confirm. Zero dimensions are now trapped in the Settings dialog.
          Why only by Center? And only length and not number of interval?
          Sure I can Unlock,move resize, lock but... ๐Ÿ˜„
          or I miss something?
          It was originally set by 'corner' at pt1, but due to popular demand it quickly changed to by 'center' at pt1.
          It IS more logical.
          It is after all a 'Work Plane' and you simply make it as big as you want...
          With the new context-menu 'Delete' tools it's easy to remove unneeded ones and make a new one... ๐Ÿ˜’
          If you set the plane's size you can have a grid [optional] with whatever spacing you want - e.g. entering a grid height larger than the plane's height gives just horizontal clines...
          You could even make two overlapping WorkPlanes with aligning grids.Capture.PNG
            Why only by Center?
            And only length and not number of interval? (ok this can be made but ask a calculate ๐Ÿ˜„
            • EarthMoverE Offline
              EarthMover
              Thanks TIG. Brilliant idea to fix the perp plane issue. Works like a charm. Thanks for adding the context menu delete function. Big Help!
              Work planes are also great for intersect slicing!
              Content Creator at Skapeup
                Yes "It is after all a 'Work Plane'" ๐Ÿ˜„
                It's easy to make intervals and then resize it on the object if I want just gride over my object face
                say I want 5 and 7 intervals (I love prime numbers ๐Ÿ’š
                I enter 5 and 7 width & height, and then 1 and 1 grig width & height ๐Ÿ˜‰
                It's rustic but all can works โ˜€
                Ps A 3D working planes?
                Ok I can unlock, and copy move multiple, lock ๐Ÿ˜„
                (or better use Grow by...tig ๐Ÿ˜‰
                  DIEGO-RODRIGUEZ
                  thanks tig.
                  excellent option, rotated 90 with the Tab key. and the option to delete
                    So to recap Pilou's technique for adding a WorkPlane to a whole [rectangular] face with desired divisions of say 7 & 5...
                    First make a new WorkPlane over the face so it's aligned/snapped onto it,.
                    Right-click to open the Settings dialog and enter 7 and 5 units, then grids at 1 and 1 units.
                    On completion right-click 'unlock' [or shortcut it - I have K and shift+K for locK/unlocK] and move it by a corner onto a face's corner,
                    Use 'Scale' on the WorkPlane and resize it in the X then Y dimensions to cover whole face.
                    'Lock' it if desired.
                    Now you have a WorkPlane that is an exact fit over the face with proportional divisions...
                    Use those to place or draw over as needed etc...Capture.PNG It's an alternative to using Move+Ctrl copy with \n in both directions on guides or lines...
                      Can you try Grow with WorkPlane, I have always a big Splatch ๐Ÿ˜ฎ
                      You are 'unlocking' it first ?
                      It works 'splatlessly' for me...
                        Ben Ritter
                        TIG, thank you very much for sharing your work. ๐Ÿ‘ ๐Ÿ‘
                        With most of the plugins, it's obvious for me to see the application. In what ways do you see this application being used?
                        Thanks. Ben
                          WorkPlane will have lots of applications - many I haven't even thought of!
                          For example, snapping objects/geometry onto a plane that's parallel to a face.plane but not necessarily overlapping it, or even just any notional plane from 3 picked points, that's not one of the standard 'views'.
                          A WorkPlane also 'slices' other geometry easily when used in conjunction with with intersect....
                          • jeff hammondJ Offline
                            โ˜€
                              Can you try Grow with Work plane, I have always a big Splat ๐Ÿ˜ฎ
                              I want copy *10 the "Work plane"
                              I just make *10 on X axis , 2 as X spacing, all the rest = 0
                              works fine for -2 as x spacing โ˜€
                              all is created as I see it on the Outliner, but at the end Splat
                              Edit Splat for 2 et -2 ! So very curious ๐Ÿ˜ฒ
                              wplane.skp
                                @ Tig you can use only Scale for make the fit on the face ๐Ÿ˜‰
                                • CadFatherC Offline
                                  CadFather
                                  this is turning into a fun ruby too - what about if the c-lines were shorter? (one could always create infinite ones from them)
                                    No problem for make copy move multiple โ˜€
                                    But always Splate
                                    V6 with grow + Work plane don't works ๐Ÿ˜ž
                                    V7 with grow + Work plane
                                    works with half : following X spacing is negative or not ๐Ÿ˜ฎsplat1.png
                                    • kenK Offline
                                      ken
                                      The added function of the tab, rotating the plane 90 degrees, and the content menu deleting is to perfect. Glad to see this plugin has generated some activity.
                                      Thanks TIG
                                      • W Offline
                                        watkins
                                        Dear TIG,
                                        As CADFather suggested, shorter clines would be good. I haven't tried this plugin yet, but it strikes me that it would make an excellent alignment feature too, particularly if having made the feature one could drag it to a point while retaining the alignment with the plane.
                                        Thank you for all your hard work.
                                        Kind regards,
                                        Bob
                                          CadFather
                                          very interesting Ken....made me smile.. ..'half of infinity'.. ..gonna use that in class! ๐Ÿ˜ฒ
                                          • kenK Offline
                                            ken
                                            Maybe, the clines could be 1/2 of infinite. That way the ends would show up on my large monitor.
                                            Ken
                                            Darn, don't know how to bring a smilie into this message. So just imagine a smiling face.
                                            Cadfather, fast fingers, slow eyes.
                                            • 2 / 10
