    [Plugin] Work Plane
    183 Posts 32 Posters 133.1k Views 32 Watching
    • CadFatherC Offline
      CadFather
      this is turning into a fun ruby too - what about if the c-lines were shorter? (one could always create infinite ones from them)
        No problem for make copy move multiple โ˜€
        But always Splate
        V6 with grow + Work plane don't works ๐Ÿ˜ž
        V7 with grow + Work plane
        works with half : following X spacing is negative or not ๐Ÿ˜ฎsplat1.png
        • kenK Offline
          ken
          The added function of the tab, rotating the plane 90 degrees, and the content menu deleting is to perfect. Glad to see this plugin has generated some activity.
          Thanks TIG
          • W Offline
            watkins
            Dear TIG,
            As CADFather suggested, shorter clines would be good. I haven't tried this plugin yet, but it strikes me that it would make an excellent alignment feature too, particularly if having made the feature one could drag it to a point while retaining the alignment with the plane.
            Thank you for all your hard work.
            Kind regards,
            Bob
              CadFather
              very interesting Ken....made me smile.. ..'half of infinity'.. ..gonna use that in class! ๐Ÿ˜ฒ
              • kenK Offline
                ken
                Maybe, the clines could be 1/2 of infinite. That way the ends would show up on my large monitor.
                Ken
                Darn, don't know how to bring a smilie into this message. So just imagine a smiling face.
                Cadfather, fast fingers, slow eyes.
                • EarthMoverE Offline
                  EarthMover
                  Quick video I made showing a little of WorkPlane.rb in action -
                  YouTube - Workplane.rb - A Sketchup plugin
                  by AprC8Life
                  [flash=480,385:87khe87q]http://www.youtube.com/v/xf56s_rKguw?fs=1&hl=en_US[/flash:87khe87q]
                  Content Creator at Skapeup
                    CadFather
                    great clip Adam.. is that you playing too?
                      EarthMover
                      The music? No. The video is done with all generic stuff that comes with Camtasia 7. Took about 10 minutes to edit and upload straight from Camtasia to Youtube. Then with Jim's SCF youtube bookmark, it embedded quick and easy. I figured I'd upgrade my Camtasia and drop my Screencast.com subscription, as it's a hassle. Glad you like the demo vid. It's always a big pain to try and draw details onto a busy surface, but with this plugin, it's a breeze!
                        DIEGO-RODRIGUEZ
                        tig.
                        may add an option to enable / disable the grid?
                          EarthMover
                          Diego, if you right click before you draw the work plane, there is a grid on/off toggle.
                            @Adam - Thanks a lot! An interesting demo - so it's also useful if you are modeling prehistoric reptiles ! ๐Ÿ˜‰
                            @Diego - To change the WorkPlane Settings - i.e. the overall size or whether it has a grid [and what size that will be if it does] right-click in empty space anytime the tool is active and a dialog appears you can reset the values [if Grid? is true a second dialog will ask for those values] - see the notes in the first post...
                              DIEGO-RODRIGUEZ
                              if tig. I know.
                              I meant the possibility of changing the state of the grid, after created the work plane.
                                EarthMover
                                Haha, yes or Dragon Tails! I just wanted to show trying to draw something in the midst of a ton of inference points with and without a work plane. One of the most practical applications I think will be drawing profiles and paths amidst busy architecture. But it also works great for drawing contour lines at a specific height, precisely moving verticies with vertex tools, slicing geometry, controlling bezier curve drawing, or creating a quick piece of graph paper for precision snapping. Truly a can't live without plugin!
                                  @diego-rodriguez said:
                                  if tig. I know.
                                  I would be possible to update a preselected WorkPlane to a new size/grid spacing... I'll think about it... ๐Ÿค“
                                    DIEGO-RODRIGUEZ
                                    ooo, thank you very much Tig.
                                    and one more suggestion. only as a cosmetic.
                                    usage:
                                    run tool.
                                    I choose first point. > Previewing a ghost Workplane . (You can vary the size in vcv. For example 10,10) (units would use the current model)
                                    I choose the second point> to preview the grid phantom. (Divisions may vary)
                                    I choose the third point> is generated work plane
                                      EarthMover
                                      Or, perhaps the first two clicks define the grid size automatically. This would make sense, as typically when working in a smaller space, you need a smaller gridding. Then from the context menu you can disable or adjust the grid size to suit.
                                        DIEGO-RODRIGUEZ
                                        yes. this option looks interesting
                                          EarthMover
                                          Found another great use for work planes today......setting up spot lights! โ˜€
                                            Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                                            'New' and 'Adjust' options have been added to context-menu.
                                            'New' lets you make a new WorkPlane on the fly...
                                            'Adjust' lets you change one selected WorkPlane's Settings [Plane's h/w and Grid's h/w]
                                            Cline 'guide' rectangle and axes are now drawn whilst you are picking the points.
                                            The WorkPlane Grid is now always centered on pt-1, even if a grid-dim does not divide exactly into the plane-dim.
                                            • 3 / 10
