    Google is Listening!
    329 Posts 70 Posters 103.7k Views 70 Watching
      jhauswirth
      @jclements said:
      Perhaps utilizing multicore processing would be possible for Layout rendering?
      You guys want to know a funny thing? LayOut 2.0 on Windows
      renders in another thread while you continue to work on the
      document. What's so funny you ask? Well in LayOut 2.1 we
      had to pull out the background rendering and guess
      how many people noticed? ZERO!
      • JClementsJ Offline
        JClements
        Perhaps if you hadn't have updated/improved the SU rendering engine we would have πŸ˜„. Kind of kidding you here.
          TouchΓ©! πŸ˜„
          • PixeroP Offline
            Pixero
            Well I certainly didn't...since I don't use Layout. πŸ˜‰
            • Bryan KB Offline
              @hieru said:
              @thomthom said:
              .....a Plugin Manager would let you browse and download plugins directly from SU. And of course update when updates are available. The Plugin Manager should be available as an one-click-installer.
              Basically something like Dreamweaver's Extension Manager?
              Now there's a good idea!
                jchau2007
                I would think google should keep the SU in 32bit for the less intense users and release the 64bit for more intense users. Let us (the users)test it out and you will get your response of what we think that if the 64bit version actually benefit more to the intense users. Now a day, I believe computers set their 64bit application as their standard. I have seen laptops as low as $400 with 64bit window base application. I believe 64bit is the future if not the current then why SU stays as 32bit.
                  agamemnus
                  Peep
                  I want a way to selectively disable inferencing -- a checkbox list for which inferences should be on or off.
                  Not having that option is a major bummer for me.
                    toxik
                    I think that introducing coloured guide lines will ease a lot of work during construction.
                    Just a thought
                    Toxik
                      julyyen
                      In my opinion it will be essential to bring in SU (free and pro - especially free) linetype, lineweight, hatching, even it's a 3D modelling tool. (in fact, we all need a 2D plan before 3D modelling)
                      • PixeroP Offline
                        Pixero
                        @julyyen said:
                        2D tools by TIG here: http://forums.sketchucation.com/viewtopic.php?t=22091
                        • jeff hammondJ Offline
                          Old skool thinking!
                          πŸ˜„
                            Pout
                            There are a lot of questions/suggestions available in this topic:
                            http://forums.sketchucation.com/viewtopic.php?f=180&t=13666
                            All of them for the use of developers.
                            But if those people get the right tools, they can make better plugins and extend Sketchup possibilities.
                            It's like Pixero wrote:
                            'extend the API'!
                            πŸ˜„
                            I know it is impossible to adress everyones wishes. But if you make the API better, then more people can try to answer those wishes...
                              'extend the API'!
                              πŸ˜„
                              i'm sort of under the impression (judging by a couple of random posts by SUteam members) that they don't want to go full on in supporting plugins..
                              i'm pretty sure if they set up a depot app store type of thing then they'd have a gigantic slew of new problems to deal with.. fredoscale was a decent example of what may happen so imagine if that was happening to millions instead of thousands.
                              it'd be sort of sweet if google had an approval process of some sorts prior to rubies going live but again, that's a big undertaking in itself + we'd miss (some of) the benefit of talking directly with the developers and offering ideas/additions etc. (that could still occur but the process would be weeks/months instead of hours/days.)
                                david.
                                If I may ask, what was the fredoscale example?
                                  Due to an unknown design limitation on the API regarding the UI::Command objects, context menus began to grey out when one used the plugin.
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=28135&p=244052
                                      david.
                                      Thanks.
                                        jan-31
                                        Thanks for your input Gaieus. My observation with Sketchup in Ubuntu Koala with Wine 1.2 is very good speed using Nvidia drivers, so it must be using openGL natively. But you have a point because trying to make a raster export is disastrous. But working within Linux without doing that is snappy,apart from a garbled start screen. What I was thinking of was a Sketchup Linux written for Debian or Red Hat which has a large user base. Recently, Bricscad released a full Linux version of their CAD application and it is pretty impressive. Snappier than in Wine.
                                          Pout
                                          Jeff,
                                          I would not go that far to put the ruby plugin dev under their wings. I think the way it works now is ok.
                                          There are a lot of good plugin ideas being put in a trash can caused by the lack of some basic classes.
                                          The handling of problems with (and responsibility for) the plugin must be handled by the plugin author, not by Google SU.
                                            a4jp.com
                                            Smooth out the pencil tool lines and add points to edit the curves please.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
