    Google is Listening!
    329 Posts 70 Posters 162.6k Views 70 Watching
      jchau2007
      I would think google should keep the SU in 32bit for the less intense users and release the 64bit for more intense users. Let us (the users)test it out and you will get your response of what we think that if the 64bit version actually benefit more to the intense users. Now a day, I believe computers set their 64bit application as their standard. I have seen laptops as low as $400 with 64bit window base application. I believe 64bit is the future if not the current then why SU stays as 32bit.
        agamemnus
        Peep
        I want a way to selectively disable inferencing -- a checkbox list for which inferences should be on or off.
        Not having that option is a major bummer for me.
        • T
          toxik
          I think that introducing coloured guide lines will ease a lot of work during construction.
          Just a thought
          Toxik
            julyyen
            In my opinion it will be essential to bring in SU (free and pro - especially free) linetype, lineweight, hatching, even it's a 3D modelling tool. (in fact, we all need a 2D plan before 3D modelling)
            • PixeroP
              Pixero
              @julyyen said:
              2D tools by TIG here: http://forums.sketchucation.com/viewtopic.php?t=22091
              • jeff hammondJ
                Old skool thinking!
                πŸ˜„
                • P
                  Pout
                  There are a lot of questions/suggestions available in this topic:
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=13666
                  All of them for the use of developers.
                  But if those people get the right tools, they can make better plugins and extend Sketchup possibilities.
                  It's like Pixero wrote:
                  'extend the API'!
                  πŸ˜„
                  I know it is impossible to adress everyones wishes. But if you make the API better, then more people can try to answer those wishes...
                  • jeff hammondJ
                    'extend the API'!
                    πŸ˜„
                    i'm sort of under the impression (judging by a couple of random posts by SUteam members) that they don't want to go full on in supporting plugins..
                    i'm pretty sure if they set up a depot app store type of thing then they'd have a gigantic slew of new problems to deal with.. fredoscale was a decent example of what may happen so imagine if that was happening to millions instead of thousands.
                    it'd be sort of sweet if google had an approval process of some sorts prior to rubies going live but again, that's a big undertaking in itself + we'd miss (some of) the benefit of talking directly with the developers and offering ideas/additions etc. (that could still occur but the process would be weeks/months instead of hours/days.)
                      david.
                      If I may ask, what was the fredoscale example?
                        Due to an unknown design limitation on the API regarding the UI::Command objects, context menus began to grey out when one used the plugin.
                        • jeff hammondJ
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=28135&p=244052
                            david.
                            Thanks.
                              jan-31
                              Thanks for your input Gaieus. My observation with Sketchup in Ubuntu Koala with Wine 1.2 is very good speed using Nvidia drivers, so it must be using openGL natively. But you have a point because trying to make a raster export is disastrous. But working within Linux without doing that is snappy,apart from a garbled start screen. What I was thinking of was a Sketchup Linux written for Debian or Red Hat which has a large user base. Recently, Bricscad released a full Linux version of their CAD application and it is pretty impressive. Snappier than in Wine.
                              • P
                                Pout
                                Jeff,
                                I would not go that far to put the ruby plugin dev under their wings. I think the way it works now is ok.
                                There are a lot of good plugin ideas being put in a trash can caused by the lack of some basic classes.
                                The handling of problems with (and responsibility for) the plugin must be handled by the plugin author, not by Google SU.
                                  a4jp.com
                                  Smooth out the pencil tool lines and add points to edit the curves please.
                                  • jason_marantoJ
                                    jason_maranto
                                    For those who don't know the answers and discussion about ideas/votes are happening here:
                                    Error 404 (Not Found)!!1
                                    (www.google.com)
                                    Best,
                                    Jason.
                                      Jim57
                                      @pout said:
                                      Jeff,
                                      Poutβ€”
                                      Sure, developers should write good code, but I think Google SU is pretty irresponsible with the way they handle Plugins.
                                      It's okay if they want the program to be a platform for developers, it builds community for giveaway software. However, they know full well that the vast majority of developers are unpaid volunteers, by definition amateurs. And who says amateurs should know how to code as well as a pro, let alone be able to afford the time to debug a plugin to the professional level?
                                      Issue 2β€” Google hosts the forum, including a discussion for Plugins. However, there is no central directory, no place where all plugins are listed, rated, reviewed, explained and linked to. Right now you have to ask around, search around, track down all the posts and do a lot of homework. If this is what it takes to make a functional program (and the consensus is that plugins MAKE Sketchup, why not make it easier to figure out what you need to do the job you are working on?
                                      Issue 3β€” You download a Ruby, open the folder and dump all its contents in the Plugins folder. No wonder there are naming conflicts! Give us a Plugins Manager. Rewrite the program so that you put Rubys in the Plugins Folder inside their own folder. With a moderate selection of Rubys I have 50 some items in there and no clue as to what goes with what. How are we supposed to debug if there is a problem? Dump everything and download it over again? Get real!
                                      This stuff isn't rocket science, it's basic software management. It's just fine for a giveaway program, but lots of us have the pro version and for $500 this isn't a big upgrade, it's pretty simple and obvious.
                                      Jim
                                      • jason_marantoJ
                                        jason_maranto
                                        The flip-side to that is it could be that some our best and brightest Ruby coders are here because of (rather than despite) the lack of overseers... that would make it too much like a job thus squashing the creative spirit.
                                        I'm not a big fan of micro-management of anything -- I personally prefer to have people let me do my thing my way... if that doesn't happen then I find a new playground. I'm sure there are Ruby authors who feel the same way.
                                        I mean the crux of it is they are dissatisfied with how Sketchup works and are trying to re-create it in their image. If you have to deal with oversight then you begin to take away the ability of the author to "dream out loud".
                                        I understand your desire to make things easier, and that is certainly on the mind of the Sketchup developers, but developing for the lowest common denominator is why Sketchup needs plugins in the first place.
                                        Best,
                                        Jason.
                                          sm4rt
                                          Hi Google !
                                          I don't know if this was already mentioned but we really need the orthogonal type in sketchup like AutoCAD do in order to simplify the building of object with Sketchup.
                                          And I also really need a bezier curves tool develloped by sketchup. In fact I've found a plugin that help me to build some special curves but this tool isn't truelly efficient.
                                          Hope this will come asap πŸ˜‰
                                          • PixeroP
                                            Pixero
                                            Here's something for you:
                                            http://forums.sketchucation.com/viewtopic.php?t=13563
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
