    SketchUP 8
    345 Posts 101 Posters 138.0k Views 101 Watching
    • jeff hammondJ
      @kxi system said:
      quick question, I'll save my comments for later...
      THEY TOOK OUT INTERSECT IN FREE?!?!
      not sure as i'm using pro but come on.. i highly doubt that
      • charly2008C
        charly2008
        i found it! It is now "Add Location"
        Charly
          Aerilius
          @charly2008 said:
          I miss the "Google Earth Tool > Get current view". I found only "Toggle Terrain" in the Google toolbar. Any Idea where it could be?
          Guten Abend,
          they streamlined the geo-positioning. It is now not anymore done via the Google Earth client, but via integrated Google Maps. This allows to get colored satellite image as well as more detailed terrain. You can find on the Google toolbar a new "Add Location" icon.
          Unfortunately removing the "Get current View" added some new incompatibilities.
            SpookyChick1013
            I'll be honest here. I am extremely displeased with Google's lack of response to user requests in their development of this release. Most especially, I find the fact that they REMOVED the ability to set the north angle in free version highly inconvenient, and a bit of a slap in the face; as has been said previously, you don't remove features. This is a tool I use frequently, but in all honesty, I cannot afford (or justify) the nearly $500 pricetag for the Pro version, just to keep ONE tool, and that is what it would cost me to go Pro edition with things. Solid Tools only available in Pro? Well, they would have been nice, and should have been in SU for years. Upgrading the push pull tool? good work. This is something that needed to be done for a long time. Supposedly increased support for animation, I. Don't. Need. It. I honestly could care less about animation. Not something I use. Several of my plugins being b0rkd at start up? Why am I not surprised? Further, the fact that Google has failed to get with the program and accomodate multi-core processing, and also failed to fix the poly-count issue really is ridiculous.
            At this point, I highly doubt that I will be using SUv8, either free, or Pro, until plugins become available to make up the deficiencies, notably the north angle setting. I am NOT asking for super high-end performance, I am just asking for something that works right, and has all the features I have come to expect from previous editions. I could not care less than I already do about Google Earth modeling, and frankly, the idea of retrieving components from 3dw is repulsive, considering the garbage quality of quite a few of the models, and the widespread use of the scramble plugin. Hint, folks; If you don't want other people using your models, don't upload them to a place like 3dwarehouse. Common sense here.
            What it comes down to in the end?
            "Don't be evil..."?
            Google=EPIC FAIL
            -10,000
            Translation: Don't be evil? Google; you have failed completely and utterly!
            Edit:Oh, and a simple rearrangement of the icons on the toolbars does NOT help qualify this as a new release, either.
            Yes I will still be using this program, until something better comes along, because there are not many other choices available. I did want to make my opinion known, however. Not that Google gives a rip what I as a user and potential customer want...
            https://kuromatsudriveyards.com
            Fo-su to tomo ni aran koto o...
            • Al HartA
              Al Hart
              FYI --- I transfered my ruby collection and everything seems to work. Have not actually TRIED everything yet, but at least no error messages on startup. All the tool bars come up etc. EXCEPT the IRender Plus. My Podium works, but Al Hart just notified me they have to issue an upgrade to the renderer so it works with V8.
              SketchUp 8 ruby added a new, small, bug when converting a SketchUp color (32 bits) into an integer. Technically it is an unsigned integer, and the new version burps when you convert it to a signed integer - which to old version had no problem with. We have the fix and should post a new version tomorrow - or after the weekend.
              Al Hart
              IRender nXt from Render Plus
                Jim
                Did they really not include the Solar North Toolbar in the Free version? Is it maybe just not enabled in the Preferences > Extensions dialog?
                If it is not included, then it just seems like an over-sight. The same functionality is available from a Ruby plugin, and any number of the scripters here could reproduce it in a few hours at the most.
                • brodieB
                  brodie
                  I'm pretty surprised by the new release. It's pretty ballsy to release a new version that contains no new tools. We already had bool tools (those of us who wanted them anyhow, I always found intersect geometry worked fine for me), push/pull 2.0? more like 1.1 (I originally misunderstood and thought they'd made it more like JPP which would have been more noteworthy), and all the links with other google programs aren't really new tools since you could use them before, just not linked with SU. And Layout...is that thing still around?
                  I think the update will be nice. It's not that the changes are bad, really, it's just that it looks like something a small team could have probably worked out in a couple weeks ("Bob, here's $10. Go to smustard and find something you think people will pay $95 for").
                  They didn't even bother to change the desktop icon for heaven's sake. Come on people, take some pride in your work.
                  -Brodie
                    Note - Pro only.
                    • P
                      Panga
                      Did not test the free version, but if it's real, It's worth than I thought...how to make a release by google :
                      1. Turn one of existing ruby script in a new tool (solid tool)
                      2. Add a option to an existing tool (push pull), give it a new number...but still far from what ruby scripts does.
                      3. Remove some options from the free version, to "satisfy" pro users and get on free users nerves...
                      I'm not ignoring the opengl improvements that're already welcome...but this relase is a bug fix one...And another thing : thoses fabulous dynamic components of previous release, which could be with a little imagination a good support for animating objects, not a word on it ? not any improvements for them ?
                      • wind-borneW
                        wind-borne
                        @thomthom said:
                        Note - Pro only.
                        With a Mac you just move the icons up into the main toolbar.
                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                        %(#BF80BF)[SU 8 pro
                          dedmin
                          And the Generate Report is still useless - only inches... 👎 👎
                            Aidus
                            And again, nothing included what users asked for a long time. One huge dissapointment and my choice is now 3ds max. Google you suck! 😞
                            CPU: Intel Core i7 Extreme Edition 965
                            RAM: OCZ Gold DDR3 1600MHz 12Gb
                            Video: Asus Radeon HD4870 X2 2Gb
                            Mobo: Asus P6T Deluxe 1366 Intel X58
                              Starling75
                              3ds max - US$ 3495,-
                              SU8 Pro - US$ 495,-
                              SU8 Free -US$ 0,-
                              http://www.starlingarch.cz
                                dedmin
                                SU8 Pro - US$ 495,-
                                SU8 Free -US$ 0,-
                                3ds max - US$ 3495,- work done - money flow - happy
                                SU8 Pro - US$ 495,- can't do this, can't do that - clients go away - no money - wife is gone - happy
                                • H
                                  hvanessen
                                  I have now problems with my free sketchup 8 edition, everything works perfect.
                                  I want to know why people are disappointed because nobody have said that the must go to version 8. So when you're not happy with the new version stick by the old one.
                                  I use 7 pro and al the things i miss in the 8 free version i can still do in the 7 pro version and then import in 8. For me personal i use the 7 version to create my own materials.
                                  So don't be disappointed because you can still use the 7.1 version. And perhaps we get quite soon a 8.1 version 🤓
                                  • MarianM
                                    Marian
                                    3ds max - US$ 3495,- Broke, frustrated, depressed and gray haired
                                    SU8 Free -US$ 0,- No girl, no car, no stable job, little money, yet surprisingly happy.
                                      It's all about the right tool for the right job. And that is very subjective. It's not about using a hammer OR a screwdriver.
                                        Aidus
                                        I'm talking about new features. Why that 3ds Max, Maya , Modo and others allways include something handy and really neede when SU just integrates unneded crap like layout and google earth stuff? Where is normal texturing tools for archs for example? That's why I'm calling this SU 8 - another crap from google. Google thinks that my progress with modeling stay's in one position? 😄 Come on 😄
                                        • C
                                          cadmunkey
                                          I really needed to move on from 32bit memory space. Looks like I will have to buy a render app that has an external 64bit studio. Any recommendations?
                                            Because it's fits Google's need?
                                            @Last SketchUp and Google SketchUp clearly has different agendas.
                                            I don't think Google SketchUp will be competing about features in the same line as other modeller tools. So comparisons turn into oranges and apples.
                                            Not saying that is good for the users - but just an observation of how I interpret Google SketchUp.
                                            • 17
                                            • 18
                                            • 7 / 18
