    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    SketchUP 8
    345 Posts 101 Posters 68.2k Views 101 Watching
      Panga
      Solid tools...bool tools cost around 20 $...I hope there're others improvements...does google knows what RPO means ? I don't want to throw the stone as I did not test this 8 version for the moment, but I really hope they do not fool us again...
        http://sketchup.google.com/intl/en/gsu7/download.html now refers to 7.1 again.
        SU8 download link: http://sketchup.google.com/intl/en/gsu8/download.html
        • tridemT Offline
          tridem
          Just installed the free version, it seems I can run both the new one and the old 7.08, this is great to discover the new features "safely" ๐Ÿ˜
          • honoluludesktopH Offline
            honoluludesktop
            It appears that the implementation of OpenGl is improved. V8 runs with hardware acceleration on my graphically impaired home PC. However some of my plugins do not load.
            • jeff hammondJ Offline
              I guess my main question about this is
              Does and update such as this usually include more options for the ruby writers?
                Can you please make a post in the affected plugin's thread? (include any error if you get any)
                  Error 404 (Not Found)!!1
                  (sketchup.google.com)
                  We upgraded our API's Ruby interpreter from version 1.8.0 to 1.8.6, which is a better supported, more stable version. This gives API users the benefits of hundreds of Ruby bug fixes, but version 1.8.6 is also more strict on Ruby syntax. If a script is broken, you may need to contact the script's original author to get an upgraded version.
                    More expanded changelog for SU8: http://sketchup.google.com/support/bin/answer.py?answer=115424
                      drewpoeppel
                      Looks like they removed the solar orientation setting in the geolocation area for manually setting the north angle in you model, along with dwg/dfx import, in the free version. ๐Ÿ‘Ž I wish they wouldn't take away features.
                        Solid volume display in entity info is much welcomed.
                        though it'd be nice to be able to change the units.. i draw in feet&inches but volume (for me at least) is always cubic yards..(concrete)
                        /27 for now.
                          I see only Pro version! ๐Ÿ˜ฎ
                          Have you a link?
                            Khai
                            Have you a link?
                              /27 for now.
                              Yea - we use mm - but area and volume in m.
                              Good thing is that total area for materials are now calculated correct for skewed groups/components.
                                Khai
                                YAY and bugsplatted it first run ๐Ÿ˜„
                                • EarthMoverE Offline
                                  EarthMover
                                  Wow, solid tools are super fast! Toolbar fix is also huge. So far so good! Ruby calculations seem faster as well.
                                  Content Creator at Skapeup
                                    From what I've heard, Ruby 1.8.6 is faster than 1.8.0 - though I've yet to run any number on this.
                                      remus
                                      Thom, i have recollections of jim running some tests after changing to 1.8.6 and finding it was indeed faster.
                                      • FrederikF Offline
                                        Frederik
                                        You guys are so un-grateful... ๐Ÿ˜
                                        I like "Susan"... ๐Ÿ˜‰
                                        Cheers
                                        Kim Frederik
                                          EarthMover
                                          I ran Make Fur on a sphere and it calculated over 200K polygons in 28 seconds clean. Ran the same test in SU 7.1 and the screen went white and I got the spinning circle for over two minutes.
                                          • HieruH Offline
                                            Hieru
                                            How do you do that, as it would be good to keep the old version for dwg imports?
                                            Do you simply set it up in a different folder, or is this an automatic new feature?
                                            www.davidhier.co.uk
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 17 / 18
