    [Plugin] Ruby Toolbar
    41 Posts 15 Posters 37.3k Views 15 Watching
      Jim
      Maybe I should combine the 2 plugins into 1?
        tomasz
        Jim,
        I use your plugin always when I deal with SU Ruby. Ability to run snippets would be the good addition.
        I have also noticed that your plugin doesn't work in Polish version of SU. In PL the console is called "Konsola Ruby". Is there a way to recognise the language of SU instead of the OS? I have SU6PL installed in Vista EN. πŸ˜„
        Tomasz
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          tomasz
          I have checked and
          Sketchup.get_locale
          returns 'pl' string which is correct language for SU Version (SU6 PL).
          Tomasz
          EDIT
          Substituted os_language with get_locale
            @btm
            Thx Indeed that's save and load but not in .rb in the Snippets apparently πŸ˜„
            That was my error πŸ˜„
              I'm getting this error for the Clear Console button:
              Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:94:incall'
              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:94:in moveConsole' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:66:in clearConsole'
              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:167
              C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:167:in call'
                Jim
                What is the name of your Ruby Console in the title bar?
                  "Ruby Console"
                    Jim
                    I don't understand the error, then. Does WIn32API work on 64 bit machines? Can you try this version?
                    rubytoolbar.zip
                      Yes.
                      I have a working version of a snippet that clears the console. I can compare it against the one in your plugin.
                      I'll try.
                      • E Offline
                        everywinter
                        Hi! Im a new user to ruby and i have just downloaded the file from your post but i cant seem to activate anything. I have the 'ruby console' under sketchup 'windows' but nothing's in there... Can you teach me what should i do? How should i start?
                          Jim
                          Hi Geraldine,
                          The Ruby Console you mention in the Windows menu is SketchUp's built-in Ruby Console.
                          This plugin creates a Ruby Toolbar in the View >> Toolbars menu. The toolbar provides some shortcuts for using the Ruby Console and only runs on Windows machines.
                          So to install it, you download the .zip file, and extract it. Then copy the files to your Plugins folder as follows:
                          Then start Sketchup, and open the Toolbar from the Views >> Toolbars menu.
                          To find your Plugins folder, copy and paste this line to the Ruby Console, then press ENTER.
                          Sketchup.find_support_file("plugins")
                            Jim - A wee bug I found.
                            The Show/Hide Ruby Console toolbar:
                            If you have the toolbar floating, it'll be floating in a toolbar named "Ruby Console" - which means the Show/Hide method also closes the toolbar.
                              Jim
                              Ok, thanks Thomthom. I guess the Win32 functions were finding the toolbar instead of the actual Ruby Console?
                              Anyway, made that changes, and a few other minor ones:
                              Ruby Toolbar
                              • Didier BurD Offline
                                Didier Bur
                                Thanks Jim, and happy new year.
                                DB
                                  Jim
                                  Thank you, and a happy new year to you.
                                  I am not sure if I should continue to include Win32API.so file with this plugin? Win32API.so is obsolete and we hope to be moving to something better in the near future.
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    @everywinter said:
                                    Hi! Im a new user to ruby and ... Can you teach me what should i do? How should i start?
                                    Go to this post... Ruby Newbie's Guide to Getting Started
                                    I'm not here much anymore.
                                      Jim
                                      Hello, I made a minor improvement:
                                      • Remembers most recently used folder and last loaded file between sessions.
                                      Plugin: Ruby Toolbar
                                      This Windows-only plugin creates a Toolbar for controlling the Ruby Console It can open and close the Ruby console, clear the console, loa...
                                      (sketchuptips.blogspot.com)
                                        πŸ‘
                                          ksor
                                          Why do I get this load error when I try the "Ruby Toolbar"
                                          Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/rubytoolbar/rubytoolbar.rb
                                          no such file to load -- Win32APIError Loading File rubytoolbar.rb
                                          I have attached my PlugIns and rubytoolbar folders
                                          Plugins folder
                                          rubytoolbar folder
                                          Best regards
                                          KSor, Denmark
                                          Skype: keldsor
                                            Because you also need Win32API.so in the Plugins folder to run a few tools like this on a PC.
                                            It does say on the download page:
                                            Requirements
                                            Sketchup
                                            Windows
                                            Win32API.so (if not already installed)
                                            So get it here http://forums.sketchucation.com/viewtopic.php?f=323&t=42732&p=383201&hilit=win32ole#p383201
                                            Make sure you get the version to suit your SUp version.
                                            There are some useful docs too... IF you want to dabble with the dark-arts of these .so files... BUT please learn the basics first...
                                            While you are at it, also get Win32OLE.so - as I suspect you'll need it later when you get more adventurous... πŸ˜‰
                                            • 2 / 3
