    [Plugin] Ruby Toolbar
    41 Posts 15 Posters 36.9k Views 15 Watching
      Jim
      Hi Geraldine,
      The Ruby Console you mention in the Windows menu is SketchUp's built-in Ruby Console.
      This plugin creates a Ruby Toolbar in the View >> Toolbars menu. The toolbar provides some shortcuts for using the Ruby Console and only runs on Windows machines.
      So to install it, you download the .zip file, and extract it. Then copy the files to your Plugins folder as follows:
      Then start Sketchup, and open the Toolbar from the Views >> Toolbars menu.
      To find your Plugins folder, copy and paste this line to the Ruby Console, then press ENTER.
      Sketchup.find_support_file("plugins")
        Jim - A wee bug I found.
        The Show/Hide Ruby Console toolbar:
        If you have the toolbar floating, it'll be floating in a toolbar named "Ruby Console" - which means the Show/Hide method also closes the toolbar.
          Jim
          Ok, thanks Thomthom. I guess the Win32 functions were finding the toolbar instead of the actual Ruby Console?
          Anyway, made that changes, and a few other minor ones:
          Ruby Toolbar
          • Didier BurD Offline
            Didier Bur
            Thanks Jim, and happy new year.
            DB
              Jim
              Thank you, and a happy new year to you.
              I am not sure if I should continue to include Win32API.so file with this plugin? Win32API.so is obsolete and we hope to be moving to something better in the near future.
              • Dan RathbunD Offline
                Dan Rathbun
                @everywinter said:
                Hi! Im a new user to ruby and ... Can you teach me what should i do? How should i start?
                Go to this post... Ruby Newbie's Guide to Getting Started
                I'm not here much anymore.
                  Jim
                  Hello, I made a minor improvement:
                  • Remembers most recently used folder and last loaded file between sessions.
                  Plugin: Ruby Toolbar
                  This Windows-only plugin creates a Toolbar for controlling the Ruby Console It can open and close the Ruby console, clear the console, loa...
                  (sketchuptips.blogspot.com)
                    πŸ‘
                      ksor
                      Why do I get this load error when I try the "Ruby Toolbar"
                      Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/rubytoolbar/rubytoolbar.rb
                      no such file to load -- Win32APIError Loading File rubytoolbar.rb
                      I have attached my PlugIns and rubytoolbar folders
                      Plugins folder
                      rubytoolbar folder
                      Best regards
                      KSor, Denmark
                      Skype: keldsor
                        Because you also need Win32API.so in the Plugins folder to run a few tools like this on a PC.
                        It does say on the download page:
                        Requirements
                        Sketchup
                        Windows
                        Win32API.so (if not already installed)
                        So get it here http://forums.sketchucation.com/viewtopic.php?f=323&t=42732&p=383201&hilit=win32ole#p383201
                        Make sure you get the version to suit your SUp version.
                        There are some useful docs too... IF you want to dabble with the dark-arts of these .so files... BUT please learn the basics first...
                        While you are at it, also get Win32OLE.so - as I suspect you'll need it later when you get more adventurous... πŸ˜‰
                          Dan Rathbun
                          @tig said:
                          Because you also need Win32API.so in the Plugins folder ...
                          Both files are included in the "so" zips, I posted.
                          (However, those are the only source object files from the Ruby distro, that are included.)
                            ksor
                            I got it now 😳 !
                            • and the toolbar works really fine - nice tool !
                            Best regards
                            KSor, Denmark
                            Skype: keldsor
                            • 2 / 3
