    [Plugin] Ruby Toolbar
    41 Posts 15 Posters 36.9k Views 15 Watching
      CPhillips
      Ah, much better. Yeah I was still using the old one.
      I didn't even know this subsection of the forums was here until yesterday.
      As far as detecting the window close message. It wouldn't be easy. One thing you could do is just check the position of the window ever 10 sec or so and see if it has moved/closed.
      Regards
        Why put the "ruby console" and not the "Web Console" of Jim Foltz?
        Seems it is more easy using? ๐Ÿ˜„
        (but I am totally new beginner in Ruby script ๐Ÿ’š
        PS With the Webconsole seems you can't save (bug ?) ๐Ÿ˜ฎ
          BTM
          You can save, it just doesn't say that you have the same file open after that. it's weird.
            Jim
            Maybe I should combine the 2 plugins into 1?
              tomasz
              Jim,
              I use your plugin always when I deal with SU Ruby. Ability to run snippets would be the good addition.
              I have also noticed that your plugin doesn't work in Polish version of SU. In PL the console is called "Konsola Ruby". Is there a way to recognise the language of SU instead of the OS? I have SU6PL installed in Vista EN. ๐Ÿ˜„
              Tomasz
                tomasz
                I have checked and
                Sketchup.get_locale
                returns 'pl' string which is correct language for SU Version (SU6 PL).
                Tomasz
                EDIT
                Substituted os_language with get_locale
                  @btm
                  Thx Indeed that's save and load but not in .rb in the Snippets apparently ๐Ÿ˜„
                  That was my error ๐Ÿ˜„
                    I'm getting this error for the Clear Console button:
                    Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:94:incall'
                    C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:94:in moveConsole' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:66:in clearConsole'
                    C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:167
                    C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:167:in call'
                      Jim
                      What is the name of your Ruby Console in the title bar?
                        "Ruby Console"
                          Jim
                          I don't understand the error, then. Does WIn32API work on 64 bit machines? Can you try this version?
                          rubytoolbar.zip
                            Yes.
                            I have a working version of a snippet that clears the console. I can compare it against the one in your plugin.
                            I'll try.
                            • E Offline
                              everywinter
                              Hi! Im a new user to ruby and i have just downloaded the file from your post but i cant seem to activate anything. I have the 'ruby console' under sketchup 'windows' but nothing's in there... Can you teach me what should i do? How should i start?
                                Jim
                                Hi Geraldine,
                                The Ruby Console you mention in the Windows menu is SketchUp's built-in Ruby Console.
                                This plugin creates a Ruby Toolbar in the View >> Toolbars menu. The toolbar provides some shortcuts for using the Ruby Console and only runs on Windows machines.
                                So to install it, you download the .zip file, and extract it. Then copy the files to your Plugins folder as follows:
                                Then start Sketchup, and open the Toolbar from the Views >> Toolbars menu.
                                To find your Plugins folder, copy and paste this line to the Ruby Console, then press ENTER.
                                Sketchup.find_support_file("plugins")
                                  Jim - A wee bug I found.
                                  The Show/Hide Ruby Console toolbar:
                                  If you have the toolbar floating, it'll be floating in a toolbar named "Ruby Console" - which means the Show/Hide method also closes the toolbar.
                                    Jim
                                    Ok, thanks Thomthom. I guess the Win32 functions were finding the toolbar instead of the actual Ruby Console?
                                    Anyway, made that changes, and a few other minor ones:
                                    Ruby Toolbar
                                    • Didier BurD Offline
                                      Didier Bur
                                      Thanks Jim, and happy new year.
                                      DB
                                        Jim
                                        Thank you, and a happy new year to you.
                                        I am not sure if I should continue to include Win32API.so file with this plugin? Win32API.so is obsolete and we hope to be moving to something better in the near future.
                                        • Dan RathbunD Offline
                                          Dan Rathbun
                                          @everywinter said:
                                          Hi! Im a new user to ruby and ... Can you teach me what should i do? How should i start?
                                          Go to this post... Ruby Newbie's Guide to Getting Started
                                          I'm not here much anymore.
                                            Jim
                                            Hello, I made a minor improvement:
                                            • Remembers most recently used folder and last loaded file between sessions.
                                            Plugin: Ruby Toolbar
                                            This Windows-only plugin creates a Toolbar for controlling the Ruby Console It can open and close the Ruby console, clear the console, loa...
                                            (sketchuptips.blogspot.com)
                                            • 2 / 3
