    [Plugins]$ Create image(rotate)
    32 Posts 16 Posters 29.5k Views 16 Watching
      Daniel S
      Thank you Sahi!
      Daniel S
        blajnov
        thank you
          d12dozr
          Thank you, Sahi! Super cool and couldn't be easier to use.
          Hehe ๐Ÿ˜„
          Is there a way to use this with a render engine, to make a photorealistic animation?
          http://goo.gl/f7ooYh
          • Mike LuceyM Offline
            Mike Lucey
            Thanks Sahi,
            I think this is going to be a very popular one ๐Ÿ‘
            Mike
              adrihal
              http://stroyka.in/images/smilies/an129.gif
              • shuraS Offline
                shura
                Wicked!!! Thank you so much ๐Ÿ˜
                  sahi
                  Modified script, added the ability to select each group the direction of rotation
                  In the first message
                    sahi
                    Modified script, added the rotation of the whole scene, as well as selecting the folder to save the
                      d12dozr
                      @sahi said:
                      For the test added to the script to choose the speed of rotation for each group (component)
                      It is necessary?
                      Useful for gears ๐Ÿ˜‰ ...so yes! ๐Ÿ˜„
                      • H Offline
                        hebeijianke
                        Your work is so great
                        Can you provide a multi-language version
                        Thank you
                          Jim
                          This works really well, thanks. But is seems to take a long time to export the images, and why encrypt it?
                            sahi
                            In the first message is the source file (animaciya_create.rb>> not encrypted)
                            animaciya_create_7.zip - Trial until 12/01/2010 - so it is encrypted
                            Cost $ 8
                              sahi
                              It is necessary?
                              • 3 Offline
                                3eighty
                                I love this...I have a rookie question...Can this be expoted and then impoted into a program such as Bryce and still rotate or only run in SketchUp...
                                  sahi
                                  • jeff hammondJ Offline
                                    fwiw, i'm getting a consistent bug splat with OS X.
                                    all seems to go well until i click 'start' then splat.. everytime.
                                      sahi
                                      There are mistakes, I'll work on them.
                                      Use the button "Undo" and not "Pause"
                                        stonebreaker
                                        is it possible to "animate" something like a drawer comes out of a cabinet or a door opens?
                                          sahi
                                          You can open the box, (like open, click on the "Pause") then close the box, click on the "Start" as it will click on the "Pause"
                                          • H Offline
                                            hebeijianke
                                            Thank you for your work
                                            When the plugin running I used the orbit tool of the Skethup
                                            Then it stopped running
                                            Why?
