    [Plugins]$ Create image(rotate)
    32 Posts 16 Posters 30.7k Views 16 Watching
      d12dozr
      @sahi said:
      For the test added to the script to choose the speed of rotation for each group (component)
      It is necessary?
      Useful for gears πŸ˜‰ ...so yes! πŸ˜„
      http://goo.gl/f7ooYh
      • H Offline
        hebeijianke
        Your work is so great
        Can you provide a multi-language version
        Thank you
          Jim
          This works really well, thanks. But is seems to take a long time to export the images, and why encrypt it?
            sahi
            In the first message is the source file (animaciya_create.rb>> not encrypted)
            animaciya_create_7.zip - Trial until 12/01/2010 - so it is encrypted
            Cost $ 8
              sahi
              It is necessary?
              • 3 Offline
                3eighty
                I love this...I have a rookie question...Can this be expoted and then impoted into a program such as Bryce and still rotate or only run in SketchUp...
                  sahi
                  • jeff hammondJ Offline
                    fwiw, i'm getting a consistent bug splat with OS X.
                    all seems to go well until i click 'start' then splat.. everytime.
                      sahi
                      There are mistakes, I'll work on them.
                      Use the button "Undo" and not "Pause"
                        stonebreaker
                        is it possible to "animate" something like a drawer comes out of a cabinet or a door opens?
                          sahi
                          You can open the box, (like open, click on the "Pause") then close the box, click on the "Start" as it will click on the "Pause"
                          • H Offline
                            hebeijianke
                            Thank you for your work
                            When the plugin running I used the orbit tool of the Skethup
                            Then it stopped running
                            Why?
                              i'm not sure if that was a reply to me or not but undo and pause make no difference whatsoever..
                              to rephrase my previous post-- this plugin does not work on macs
                                sahi
                                Why?
                                So it should be.
                                You can not work in SketchUp two instruments simultaneously
                                I do not have macs
                                So I could not set it up under the macs
                                I'll try to fix it ..
                                  sahi
                                  Updated plug-in in the first message. http://forums.sketchucation.com/viewtopic.php?f=323&t=30131
                                  Fixed bugs
                                    kevinski
                                    sorry but i still dont understand how to use it.
                                    I want to rotate my model on Blue Axis and i dont know what to do next.
                                    I klick on start an then on stop and nothing happens. Same problem with "Save" i click on it and the window opens but after that there is no saved fiel
                                      sahi
                                      [flash=750,550:2fj0fcm8]http://www.youtube.com/v/pjgenKahoA0[/flash:2fj0fcm8]
                                        blueman2
                                        Is this plug in still supported in sketchup 8? I don't see any recent posts and I'm considering purchasing it.
                                          In the above post Sahi says he updated the plugin. That was in November when SU 8 had been out for 2 months already.
                                            blueman2
                                            I just purchased it and it is very easy to use to create an animated rotation. Thank you. I can see where you can easily create an animated gif but I'm a little confused about creating an animated movie either by exporting as an avi (which I'm having problems with anyway) or exporting the rotation animation as part of a more involved animation which is being exported as still frames, to be converted after . This is the way I've been creating animations using "Proper Animation" Can someone clarify how to do this for me please. Thanks
                                            • 2 / 2
