    [Plugins]$ Create image(rotate)
    32 Posts 16 Posters 30.0k Views 16 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Thanks Sahi,
      I think this is going to be a very popular one πŸ‘
      Mike
        adrihal
        http://stroyka.in/images/smilies/an129.gif
        • shuraS Offline
          shura
          Wicked!!! Thank you so much 😍
            sahi
            Modified script, added the ability to select each group the direction of rotation
            In the first message
              sahi
              Modified script, added the rotation of the whole scene, as well as selecting the folder to save the
                d12dozr
                @sahi said:
                For the test added to the script to choose the speed of rotation for each group (component)
                It is necessary?
                Useful for gears πŸ˜‰ ...so yes! πŸ˜„
                http://goo.gl/f7ooYh
                • H Offline
                  hebeijianke
                  Your work is so great
                  Can you provide a multi-language version
                  Thank you
                    Jim
                    This works really well, thanks. But is seems to take a long time to export the images, and why encrypt it?
                      sahi
                      In the first message is the source file (animaciya_create.rb>> not encrypted)
                      animaciya_create_7.zip - Trial until 12/01/2010 - so it is encrypted
                      Cost $ 8
                        sahi
                        It is necessary?
                        • 3 Offline
                          3eighty
                          I love this...I have a rookie question...Can this be expoted and then impoted into a program such as Bryce and still rotate or only run in SketchUp...
                            sahi
                            • jeff hammondJ Offline
                              fwiw, i'm getting a consistent bug splat with OS X.
                              all seems to go well until i click 'start' then splat.. everytime.
                                sahi
                                There are mistakes, I'll work on them.
                                Use the button "Undo" and not "Pause"
                                  stonebreaker
                                  is it possible to "animate" something like a drawer comes out of a cabinet or a door opens?
                                    sahi
                                    You can open the box, (like open, click on the "Pause") then close the box, click on the "Start" as it will click on the "Pause"
                                    • H Offline
                                      hebeijianke
                                      Thank you for your work
                                      When the plugin running I used the orbit tool of the Skethup
                                      Then it stopped running
                                      Why?
                                        i'm not sure if that was a reply to me or not but undo and pause make no difference whatsoever..
                                        to rephrase my previous post-- this plugin does not work on macs
                                          sahi
                                          Why?
                                          So it should be.
                                          You can not work in SketchUp two instruments simultaneously
                                          I do not have macs
                                          So I could not set it up under the macs
                                          I'll try to fix it ..
                                            sahi
                                            Updated plug-in in the first message. http://forums.sketchucation.com/viewtopic.php?f=323&t=30131
                                            Fixed bugs
