    [Plugins]$ Create image(rotate)
    32 Posts 16 Posters 29.1k Views 16 Watching
      sahi
      The script takes a snapshot and saves the image in the folder where the file resides. Skp
      [flash=750,550:2e31286n]http://www.youtube.com/v/bHsZbK90YAQ[/flash:2e31286n]
      Before installation remove a script "animaciya_create.rb" from a folder "Plugins"
      $ (1.12.2010) SU 5, SU 6, SU 7, SU 8.
      • Didier BurD Offline
        Didier Bur
        Cool. It reminds me my old VR Object exporter ๐Ÿ˜’
        here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=467
        DB
          sahi
          I did not know that such a script exists
            Daniel S
            Thank you Sahi!
            Daniel S
              blajnov
              thank you
                d12dozr
                Thank you, Sahi! Super cool and couldn't be easier to use.
                Hehe ๐Ÿ˜„
                Is there a way to use this with a render engine, to make a photorealistic animation?
                http://goo.gl/f7ooYh
                • Mike LuceyM Offline
                  Mike Lucey
                  Thanks Sahi,
                  I think this is going to be a very popular one ๐Ÿ‘
                  Mike
                    adrihal
                    http://stroyka.in/images/smilies/an129.gif
                    • shuraS Offline
                      shura
                      Wicked!!! Thank you so much ๐Ÿ˜
                        sahi
                        Modified script, added the ability to select each group the direction of rotation
                        In the first message
                          sahi
                          Modified script, added the rotation of the whole scene, as well as selecting the folder to save the
                            d12dozr
                            @sahi said:
                            For the test added to the script to choose the speed of rotation for each group (component)
                            It is necessary?
                            Useful for gears ๐Ÿ˜‰ ...so yes! ๐Ÿ˜„
                            • H Offline
                              hebeijianke
                              Your work is so great
                              Can you provide a multi-language version
                              Thank you
                                Jim
                                This works really well, thanks. But is seems to take a long time to export the images, and why encrypt it?
                                  sahi
                                  In the first message is the source file (animaciya_create.rb>> not encrypted)
                                  animaciya_create_7.zip - Trial until 12/01/2010 - so it is encrypted
                                  Cost $ 8
                                    sahi
                                    It is necessary?
                                    • 3 Offline
                                      3eighty
                                      I love this...I have a rookie question...Can this be expoted and then impoted into a program such as Bryce and still rotate or only run in SketchUp...
                                        sahi
                                        • jeff hammondJ Offline
                                          fwiw, i'm getting a consistent bug splat with OS X.
                                          all seems to go well until i click 'start' then splat.. everytime.
                                            sahi
                                            There are mistakes, I'll work on them.
                                            Use the button "Undo" and not "Pause"
