    Seamless texture techniques
    35 Posts 29 Posters 15.9k Views 29 Watching
      john.warburton
      @chris fullmer said:
      Does Paintshop have an "offset" feature built into it? I just do the standard Photoshop trick of offsetting an image in the x and y directions, so that the seams then are showing in the middle of the image. Then I carefully go through and clean up the seam with clone stamp tool or whatever tool I need. Can you do it like that? I could explain it better if that makes no sense.
      I use the Simple Filters Half-Wrap plug in. This lets you wrap the image left-right, top-bottom, or both directions by 50%. You can then use editing tools (Clone for example) to deal with the adjoining edges. Similar to the offset command in Photoshop, but only works at 50% offset.
      Life's a reach, and then you gybe.
      • B
        blair
        Pete
        Which tool or method did you finally choose?
        • EarthMoverE
          EarthMover
          I use Pixplant to make seamless textures from photos I take. I'll go as far as I can with the plugin and then usually do some further tweaking using the offset filter in photoshop until it is reasonably accurate. Then back to Pixplant for the 3D maps. Never tried the Redfield plugin, but it looks interesting. Thanks for the heads up.
          Also great tutorial on color and light balancing. Thanks!!!! ๐Ÿ‘
          Content Creator at Skapeup
          • urgenU
            urgen
            ....brilliant old tutorial(If you remember ๐Ÿ˜‰ ) ...thank you to Jon again ๐Ÿ‘ ...
            http://forums.sketchucation.com/viewtopic.php?f=18&t=10694
            --pupil forever...------
            • Bob JamesB
              Bob James
              This works especially well with the new PhotoShop CS5 clone tool that assimilates the surrounding area and gives great
              This works especially well with the new PhotoShop CS5 clone tool that assimilates the surrounding area and gives great results.
              • unclebimU
                unclebim
                I use GIMP and the Low Frequency Even filter (http://registry.gimp.org/node/24636) when needed, followed by the Texturize filter (http://gimp-texturize.sourceforge.net/). Most of the time it gives good results although the texturizer tends to crash at more the 500x500px.
                • dereiD
                  derei
                  Ahh, this is why I never could use that plugin ๐Ÿ˜„ ... I tried again and it was a first ! ๐Ÿ˜„
                  -but this means that my image must be less than 250x250 px ๐Ÿ˜ž
                  DESIGNER AND ARTIST DEREI.UK
                    Argh! ๐Ÿ˜
                    I wrote a whole tutorial and when pressing Submit something went wrong and it didnt get posted. Well well I'll try to rewrite it AGAIN...
                    It's always a cool habit in case of post of more 3 lines
                    to copy past in the NoteBook before any Submit ๐Ÿ˜‰
                    You don't know how many time this little trick can be save!
                    It's very usefull too when you write an answer on a Net Mail ๐Ÿ˜’
                    • EdsonE
                      Edson
                      @aerilius said:
                      I often use the same technique with the brightness correction. I always thought it is a bit unprofessional and Photoshop owners would surely have a real tool for that, but it's great to see that others are doing it the same way.
                      I have already tried some texture programs or plugins and wasn't satisfied as they often created just a blurry cross-fading without considering fine details like grooves of a wall.
                      Here are two ways how I do it (PaintshopPro tutorial for Edson ๐Ÿ˜„)
                      thanks, aerilius.
                      edson mahfuz, architect| porto alegre โ€ข brasil
                      http://www.mahfuz.arq.br
                      • HieruH
                        Hieru
                        Some really great advice and application references on this thread ๐Ÿ‘
                        The tutorial on brightness level correction was particularly helpful. Does anyone know of a similar method for levelling out the colour in a texture?
                        I'm trying to create some carpet textures but I keep getting colour banding resulting from uneven colouring in the image I'm tiling.
                        www.davidhier.co.uk
                        • N
                          nrevk niatpak
                          there's also this method http://loadproject.blogspot.com/search/label/tutorials...
                          i sometimes use it in addition to the traditionnal offset thing...
                          pix plant is also a good plug
                          and there are lots of tips on the cg textures website ( tutorials section )
                          have fun
                          • E
                            Ecuadorian
                            Thanks, Jan! ๐Ÿ‘
                            ![Just using GIMP's "Make Seamless" filter](/uploads/imported_attachments/IAhm_JustwithGIMPsSeamlesstexture.jpg "Just using GIMP's "Make Seamless" filter")
                            Following Pixero's tutorial
                            -Miguel Lescano
                              drfabinex
                              This is a great little free seamless texture maker.
                              Perfect for quick and dirty texture making:
                              Texture Studio
                              http://www.blitzbasic.com/Community/posts.php?topic=46368
                              • Mike LuceyM
                                Mike Lucey
                                @pixero said:
                                Argh! ๐Ÿ˜
                                Short Photoshop tutorial:
                                First make sure the image is somewhat evenly lit. Otherwise it will be impossible to make it tileable.
                                If it isnt, do this: Make a duplicate layer of the image and turn down saturation to grayscale and invert it.
                                Increase contrast with Levels if needed. Then gaussian blur the image quite much as we just want to correct over all lighting. Now set that layers blend mode to overlay and turn down opacity until the image looks more evenly lit.
                                What "overlay" does is that it darkens the bright parts and lightens the dark parts so we hopefully ends up with a more evenly lit image.
                                Now make duplicates of both layers and flatten then. This way you have the original layers there for any future editing.
                                With the two layers flattened go to Filters->Other->Offset and set horisontal and vertical offset to half the image width.
                                Make sure you have "wrap around" choosen.
                                Now clone away the edges and use several different clone sources so it's not obvious its a cloned image.
                                For images that need much editing it can be a good idea to have a copy of the un offset image underneath and use a layermask on the top layer to paint away the edges and show the image underneat.
                                A good practice is also to remove any too obvious part of the texture as these things makes tileing more visible.
                                Another good rule is to use textures that are quadratic with sizes such as 256x256, 512x512, 1024x1024 and so on since they use the least amount of memory compared to their size.
                                Hope this helps!
                                Thanks for the tip Jan ๐Ÿ‘
                                • bagateloB
                                  bagatelo
                                  I use a action in photoshop, who quadruply the image.
                                  quadruply.zip
                                  • 2 / 2
